[geos-devel] Question about geos::io::Unload::Release()
Mateusz Łoskot mateusz at loskot.net
Sun Mar 12 06:45:31 EST 2006
strk at refractions.net wrote:
> static lifetime should be ok. I dunno if it's used by client code,
> anyway it might be useful to have a 'default' factory to use instead
> of having to construct (and maintain alive) a custom one. I'd move
> access to it to GeometryFactory::defaultInstance()
I see the idea behind default factory.
So, I'd make it a singleton, constructed on first request of its
instance. As I understand defaultInstance() is sucha a solution.
The only problem is to properly define Singleton class.
Here is some simple proposal:
template<class T>
class Singleton
private:
     class InstancePtr
     public:
         InstancePtr() : m_ptr(0) {}
         ~InstancePtr() { delete m_ptr; }
         T* Get()
             return m_ptr;
         void Set(T* p)
             if(p!= 0)
                 if (m_ptr != 0)
                     delete m_ptr;
                 m_ptr = p;
     private:
         T* m_ptr;
     static InstancePtr m_instptr;
     Singleton();
     Singleton(const Singleton&);
     Singleton& operator=(const Singleton&);
public:
     static T* Instance()
         if(m_instptr.Get() == 0)
             m_instptr.Set(new T());
         return m_instptr.Get();
But it may be better defined using smart pointers as well.
Cheers
Mateusz Łoskot
http://mateusz.loskot.net
