[geos-devel] [UTF] envelope_class_test.cpp fixed for Boost 1.33
strk at refractions.net
Mon Mar 13 09:30:54 EST 2006
On Mon, Mar 13, 2006 at 03:16:44PM +0100, Mateusz Å?oskot wrote:
> strk at refractions.net wrote:
> >On Mon, Mar 13, 2006 at 01:44:43PM +0100, Mateusz Ã
?oskot wrote:
> >>So, should I start?
> >You're welcome.
> OK, so I move to TUT.
> I'd suggest to define base dirs structure as follows:
> geos\sources
> geos\tests\unit
> geos\tests\unit\tut - here sources of TUT
> geos\tests\unit\test - here structure of files and subdirs with tests
> Is this OK?
> Simply, I'd need to have path to include TUT header fixed ;-)
Isn't it a single header file ?
I'd place it in
geos/tests/unit/whatever_it_is_named.h
--strk;
