[geos-devel] Why WKBConstants is a namespace?
Mateusz Łoskot
mateusz at loskot.net
Mon Mar 20 08:05:27 EST 2006
strk at refractions.net wrote:
> On Mon, Mar 20, 2006 at 01:13:32PM +0100, Mateusz Å?oskot wrote:
>>Why WKBConstants is a namespace instead of enum?
> It was a namespace in Java (an interface):
> public interface WKBConstants {
> int wkbXDR = 0;
> int wkbNDR = 1;
> int wkbPoint = 1;
> int wkbLineString = 2;
> int wkbPolygon = 3;
> int wkbMultiPoint = 4;
> int wkbMultiLineString = 5;
> int wkbMultiPolygon = 6;
> int wkbGeometryCollection = 7;
> As you can see an enum won't be able to hold wkbPoint
> and wkbNDR with the same value.
Why?
AFAIK it will be able.
C++ Standard says in "7.2 Enumeration declarations":
"If the first enumerator has no initializer, the value of
the corresponding constant is zero. An enumerator-definition without an
initializer gives the enumerator the value
obtained by increasing the value of the previous enumerator by one.
[ Example:
enum { a , b , c =0 };
enum { d , e , f=e +2 };
defines a, c, and d to be zero, b and e to be 1, and f to be 3.
—end example]"
As you can see:
is equivalent of:
enum { a = 0, b = 0, c = 0 };
> Also, it might grow including flags for dimensionality
> and SRID presence or whatever ends up being a WKB
> constant.
Yes, but those would be placed to separate enums.
It will also provide better type-safety in some cases.
Cheers
Mateusz Łoskot
http://mateusz.loskot.net
