[geos-devel] Pedantic build of GEOS
strk at refractions.net
Tue Mar 21 06:07:37 EST 2006
By building with -pedantic on I get warnings about the
use of 'long long'. Do you have suggestion as how to
change it to a standard name ?
About virtual destructor I agree we should fix that.
Patches welcome.
--strk;
On Mon, Mar 20, 2006 at 11:28:35PM +0100, Mateusz Å?oskot wrote:
> Hi,
> A few minutes ago, I tried to build GEOS with -pedantic and -ansi
> switches on.
> The only *errors* I got were related to extra semicolons at the end of
> functions body, e.g.:
> void foo()
> ^^^ - extra semicolon
> I removed them and did complete rebuild.
> Then I made short analysis of warnings.
> Almost all warnings were related to missing virtual destructors in base
> classes that have some virtual member functions.
> I reported it as a bug, a critical bug:
> Bug #73 - Many classes have no virtual destructor but having virtual
> member functions
> I managed to identify 25 classes that need virtual destructors.
> Is there any rationale for not adding virtual destructors?
> I don't see any and I'd say it is pretty critical to add this
> destructors, because it may cause serious bugs, even memory leaks.
> After those destructors are added I think it would be helpful to add
> -pedantic and -ansi switches to default set of compilator flags for GEOS.
> Today, we were discussing about it with strk and Norman on the #postgis
> channel and there was no consensus but I'd stronlgy suggest to add those
> flags. Why not to help compiler help us :-)))
> Cheers
> Mateusz Åoskot
> http://mateusz.loskot.net
> geos-devel mailing list
> geos-devel at geos.refractions.net
> http://geos.refractions.net/mailman/listinfo/geos-devel
State-collected Geographic Data is public property !
Reject the INSPIRE directive.
Sign the petition: http://petition.publicgeodata.org
