[geos-devel] Bug #81 - Memory access violation in
LineString::getStartPoint()
Mateusz Łoskot
mateusz at loskot.net
Thu Mar 30 10:25:38 EST 2006
Forgive me that I may post redundant messages to the list but I think
this one is very important.
Below I pasted Bug Report #81 I've just submitted:
http://postgis.refractions.net/bugs/bug.php?op=show&bugid=81&pos=4
I'd be very glad if we could discuss this report in details,
verify if this is really a bug, but no my mistake and then
let's try to take some decisions about GEOS design in relation to JTS
that would help GEOS get stable and mature C++ code.
Please, forgive me every hard word I give but this bug made me
really bad ;-)))
OK, let's start the show.
Today, when I was woring on Unit Tests I found a pretty serious bug
causing memory access violation error. Here is the story:
// Factory object preparation
const int srid = 1;
geos::geom::PrecisionModel pm(1.0);
geos::geom::GeometryFactory factory(&pm, srid),
// Use factory to create empty LinearRing
LinearRingPtr ring = factory.createLinearRing();
// ring is empty, but let's see what will happen
PointPtr x = ring->getStartPoint(); <--- BUM!
The line marked with BUM! causes memory access violation error.
Here is descriptive backtrace with complete call chain (lines marked
with <--- are executed during step-by-step debugging):
1.
1.1.
Point* LineString::getStartPoint() const {
if (isEmpty()) {
return new Point(NULL, NULL); // <----
return getPointN(0);
2. Point(NULL, NULL); <---
Parameters:
newCoord = NULL
factory = NULL
2.1.
Point::Point(CoordinateSequence *newCoords, const GeometryFactory *factory)
: Geometry(factory) <---
3.
Geometry(factory)
factory = NULL
3.1.
Geometry::Geometry(const GeometryFactory* newFactory)
factory=newFactory; <--- [1]
SRID=factory->getSRID(); <--- [2] BUUUUM!
envelope=NULL;
userData=NULL;
[1]
newFactory = NULL, so factory gets becomes null pointer
[2] BUUUM!
factory is a null pointer and calling member on a null pointer value
causes undefined behaviour!
4. Finally, GeometryFactory::getSRID() throws
MEMORY ACCESS VIOLATION ERROR!
Summary:
- the Geometry constructor is used incorrectly
- or this constructor is incorrectly designed to handle all valid cases
- This is another example of ***JAVISMS***.
JTS version of getStartPoint is defined as follows:
public Point getStartPoint() {
if (isEmpty()) {
return null; // <--- [3]
[3] returning null reference is completely different semantic of
returning pointer to newly allocated object, what happens in GEOS'
version of getStartPoint!!!
GEOS' version of getStartPoint is buggy in two ways:
1. Causes memory access violation
2. There is logical bug: how can user expect to get Point object
returned from *empty* LinearRing??? Such behaviour does not make sense.
It's also, what is most important, incompatible behaviour with that in
JTS version!
Cheers
Mateusz Łoskot
http://mateusz.loskot.net
