[geos-devel] createEmptyGeometry() creates
instance ofGeometryCollection
Mateusz Łoskot
mateusz at loskot.net
Thu Mar 30 17:04:39 EST 2006
Martin Davis wrote:
> Yes. The spec doesn't cover this, but I chose to use an empty
> GeometryCollection as a "typeless" empty geometry, for methods which
> need to return one. The createEmptyGeometry method is just a
> convenience method for this convention.
OK, I understant it.
> Anyway, what else could that method return that would make sense
> (given that it has no type information)?
It depends on the idea behind "empty geometry" or "null geometry" [1].
As I know, OGC Simple Feature Spec. explains that empty geometry
represents empty point set (empty set of coordinates).
According to my understanding:
Point is empty if it contains "uninitialized" coordinates
MultiPoint is empty if it contains no points in its set.
etc.
There is also a distinction between empty and null.
NULL means something undefined, uninitialized - something unsafe.
EMPTY means something well constructor but with empty set of points.
In some case, NULL object can be compared to EMPTY object with true result.
So, I think isEmpty() function should check the state of the coordinates
set of Geometry return appropriate value (true/false).
[1] Saying "null geometry" I think about logical meaning but not the
physical representation of instance of geometry: null reference/null
pointer.
Cheers
Mateusz Łoskot
http://mateusz.loskot.net
