[geos-devel] Is empty LinearRing closed?
Martin Davis mbdavis at VividSolutions.com
Thu Mar 30 17:47:02 EST 2006
> In my opinion this test is necessary to be checked
> explicitly. LinearRing is of type of LineString, so it is
> possible to pass LinearRing where LineString is expected, and
> the other way. So, checking "static state" of those two types
> may result in wrong asnwer.
No, the point is that if the LinearRing is valid, isClosed always returns the correct answer.  It doesn't matter where this method is evaluated.
> The IsEmpty function checks emptiness of geometry and returns
> TRUE if the geometry is empty or FALSE if the geometry is not empty.
This *IS* the way it is implemented in JTS/GEOS.
> So, I understand this behaviour as very dynamic. LineString X
> can become a LinearRing and vice versa.
Well, a LineString can't just change type into a LinearRing.  But if you're saying that a LineString might be closed, yes I agree and JTS/GEOS will return the right answer in this case (for a LineString, isClosed checks the endpoints are equal).
Anyway, this isn't a big deal IMHO - I'd be perfectly happy changing the LinearRing method so it just uses the LIneString implementation.
Martin Davis, Senior Technical Architect
Vivid Solutions Inc.      www.vividsolutions.com
Suite #1A-2328 Government Street Victoria, B.C. V8T 5G5
Phone: (250) 385 6040 - Local 308 Fax: (250) 385 6046
> -----Original Message-----
> From: geos-devel-bounces at geos.refractions.net
> [mailto:geos-devel-bounces at geos.refractions.net] On Behalf Of
> Mateusz Loskot
> Sent: March 30, 2006 2:35 PM
> To: GEOS Development List
> Subject: Re: [geos-devel] Is empty LinearRing closed?
> Martin Davis wrote:
> > But the definition of LinearRing is that the start point equals the
> > end point.   This makes the test unnecessary for a valid LinearRing.
> >  However, maybe it's more general to use the explicit test.
> Empty LineString in OGR is created explicitly as empty set of
> points + collection (array) of points is UNDEFINED:
>  * Create an empty line string.
> OGRLineString::OGRLineString()
>     nPointCount = 0;
>     paoPoints = NULL;
>     padfZ = NULL;
> > As for an empty LinearRing, well, I don't know of any
> semantics which
> > covers this.
> I think its simple to understand but quit difficult to
> implement this semantic properly. Here is my understanding of
> the emptiness (according to MySQL, ArcSDE impl. and OGC
> Simple Feature Spec.):
> 1. Empty geometries contain no coordinates. IOW, geometry is
> empty if it does not have any coordinates.
> 2. Following properties of empty geometry are not defined as
> well: exterior, interior, and boundary. According to ArcSDE,
> an empty geometry has a NULL envelope, boundary, interior,
> and exterior.
> 3. Empty geometry is always simple.
> 4. I like the idea of MySQL Spatial Ext. that empty geometry
> has dimension set to -1 (undefined).
> 5. Empty surface geometry has area equal to 0, empty curves(
> linestrings and multilinestrings) have a 0 length.
> NOW THE MOST IMPORTANT:
> That clearly means it's *incorrect* to set that some type
> *always* returns true or false. This behaviour is dynamic,
> depending on current state of geometry (if it contains empty
> set of points or not).
> Please, not that some of types of OGC Geometries has a
> logical meaning and they are not required to be represented
> as accurate instance of such type.
> I mean, ArcSDE does not use LinearRing at all, but only
> LineString type
> (exteriorRing() returns instance of LineString but not
> LinearRing). Second, the LineString becomes LinearRing as OGC
> Simple Feaure Spec. says:
> "A LinearRing is a LineString that is both closed and simple."
> > This might be an angels-on-the-head-of-a-pin kind of thing.  If you
> > don't like the JTS semantics for your particular use-case,
> you should
> >  just implement your own test.
> The semantic is clearly explained in OGC Spec. but it's
> implemented incorrectly.
> Cheers
> Mateusz Łoskot
> http://mateusz.loskot.net
> geos-devel mailing list
> geos-devel at geos.refractions.net
> http://geos.refractions.net/mailman/listinfo/geos-devel
