[geos-devel] Building geos-2.2.0 on fedora core 5 Again
    Mike Leahy
    mgleahy at alumni.uwaterloo.ca
    Thu Mar 30 23:25:38 EST 2006
Hey Simon,
I haven't tried compiling geos on Fedora, but I've had similar problems
with other stuff - it's an issue with gcc-4.1.1 being more strict than
earlier versions.  If you can edit the source code that contains those
errors, and remove the unwanted 'extra qualifications'.  E.g., in the
file /source/headers/geos/geom.h on line 361, remove the text
"geos::Coordinate::" from the code...do the same for any similar extra
qualification errors.  After you clean up those errors, if you're lucky
it will compile, if you're less lucky, you'll find more extra
qualifications to clean up.  If you're unlucky, you'll find something
harder to deal with.
Good luck,
Mike
Simon O'Malley wrote:
> Hi All
> Not sure if this is a list or a gmail problem as this message never showed
> up. If this is a double post please ignore.
> Has anyone successfully built geos-2.2.0 on fedora core 5.
> I get the following errors when running make.
> [root at nazgul geos-2.2.0]# make
> Making all in source
> make[1]: Entering directory `/usr/src/postgres/geos-2.2.0/source'
> Making all in geom
> make[2]: Entering directory `/usr/src/postgres/geos-2.2.0/source/geom'
> if /bin/sh ../../libtool --mode=compile --tag=CXX g++ -DHAVE_CONFIG_H -I.
> -I. -I../../source/headers -I../../source/headers/geos
> -I../../source/headers -DGEOS_VERSION=""2.2.0""    -g -O2 -MT
> Coordinate.lo-MD -MP -MF ".deps/Coordinate.Tpo" -c -o
> Coordinate.lo Coordinate.cpp; \
> then mv -f ".deps/Coordinate.Tpo" ".deps/Coordinate.Plo"; else rm -f
> ".deps/Coordinate.Tpo"; exit 1; fi
> mkdir .libs
>  g++ -DHAVE_CONFIG_H -I. -I. -I../../source/headers
> -I../../source/headers/geos -I../../source/headers -DGEOS_VERSION=2.2.0 -g
> -O2 -MT Coordinate.lo -MD -MP -MF .deps/Coordinate.Tpo -c Coordinate.cpp
> -fPIC -DPIC -o .libs/Coordinate.o
> ../../source/headers/geos/geom.h:361: error: extra qualification
> 'geos::Coordinate::' on member 'setNull'
> ../../source/headers/geos/geom.h:367: error: extra qualification
> 'geos::Coordinate::' on member 'getNull'
> ../../source/headers/geos/geom.h:371: error: extra qualification
> 'geos::Coordinate::' on member 'Coordinate'
> ../../source/headers/geos/geom.h:377: error: extra qualification
> ../../source/headers/geos/geom.h:384: error: extra qualification
> ../../source/headers/geos/geom.h:394: error: extra qualification
> ../../source/headers/geos/geom.h:400: error: extra qualification
> 'geos::Coordinate::' on member 'setCoordinate'
> ../../source/headers/geos/geom.h:406: error: extra qualification
> 'geos::Coordinate::' on member 'equals2D'
> ../../source/headers/geos/geom.h:416: error: extra qualification
> 'geos::Coordinate::' on member 'compareTo'
> ../../source/headers/geos/geom.h:432: error: extra qualification
> 'geos::Coordinate::' on member 'equals3D'
> ../../source/headers/geos/geom.h:436: error: extra qualification
> 'geos::Coordinate::' on member 'makePrecise'
> ../../source/headers/geos/geom.h:441: error: extra qualification
> 'geos::Coordinate::' on member 'distance'
> ../../source/headers/geos/geom.h:447: error: extra qualification
> 'geos::Coordinate::' on member 'hashCode'
> ../../source/headers/geos/geom.h:459: error: extra qualification
> make[2]: *** [Coordinate.lo] Error 1
> make[2]: Leaving directory `/usr/src/postgres/geos-2.2.0/source/geom'
> make[1]: *** [all-recursive] Error 1
> make[1]: Leaving directory `/usr/src/postgres/geos-2.2.0/source'
> make: *** [all-recursive] Error 1
> geos-devel mailing list
> geos-devel at geos.refractions.net
> http://geos.refractions.net/mailman/listinfo/geos-devel
