[geos-devel] Envelope of empty Polygon
Martin Davis mbdavis at VividSolutions.com
Fri Mar 31 12:03:37 EST 2006
JTS defines a concept of a null Envelope object state for precisely this reason.
The reason for returning a null Envelope object rather than null is that in my experience most callers of getEnvelopeInternal want something they can test against.  If null was returned calling code would need a special check for every call.
This is the same reason that empty Geometries are defined.  Often it simplifies code if there is something there, rather than null.
Martin Davis, Senior Technical Architect
Vivid Solutions Inc.      www.vividsolutions.com
Suite #1A-2328 Government Street Victoria, B.C. V8T 5G5
Phone: (250) 385 6040 - Local 308 Fax: (250) 385 6046
> -----Original Message-----
> From: geos-devel-bounces at geos.refractions.net
> [mailto:geos-devel-bounces at geos.refractions.net] On Behalf Of
> Mateusz Loskot
> Sent: March 30, 2006 10:14 PM
> To: GEOS Development List
> Subject: [geos-devel] Envelope of empty Polygon
> Hi,
> I'm bringing next subject to discuss.
> The main question is what should be returned by getEnvelope()
> called on empty polygon?
> Here is simple use case:
> GeometryFactory factory(...);
> // create empty polygon
> Polygon* poly = factory.createPolygon();
> // request for its envelope
> Geometry* geo = 0;
> geo = poly->getEnvelope();
> geo->isEmpty(); // <--- THE PROBLEM
> As I revealed, when exterior ring is empty geometry,
> getEnvelope() returns or creates instance of envelope object.
> This object is initialized by Envelope::setToNull(). So,
> returned envelope for empty polygon has following
> coordinates: minx = -1.0 maxx = 0.0 miny = -1.0 maxx = 0.0
> Is this correct behaviour?
> Is empty polygon assumed to return non-empty envelope as above?
> Cheers
> Mateusz Łoskot
> http://mateusz.loskot.net
> geos-devel mailing list
> geos-devel at geos.refractions.net
> http://geos.refractions.net/mailman/listinfo/geos-devel
