[geos-devel] Re: Problems with installation of geos on RedHat 9 (third try, i hope this is text)
Johan V jvhoppli at gmail.com
Thu May 18 03:12:30 EDT 2006
Thx, In postgis_geos_version.h stood that version 1.0 was needed. I
now tried it with a rpm package of the geos 1.0 version, and i didn't
get any error. But now I'll have to post on the postgis mailing list
cause now i get error for their product :-)
grz
Johan
2006/5/17, strk at refractions.net <strk at refractions.net>:
> Something is wrong with postgis configuration.
> 1.1.2 should not try to build lwgeom_geos_wrapper.o
> when building against geos-3.0.0.
> See what's in postgis_geos_version.h
> On Wed, May 17, 2006 at 03:21:30PM +0200, Johan V wrote:
> > I'm running a Postgresql "8.0.6-1PGDG" database on Redhat 9 and I'm
> > trying to install geos (from cvs 3.0.0) for use with Postgis &
> > Postgresql. After the configure (see below) I do a make and this is
> > the output (see after the configure part):
> > lwgeom_geos_wrapper.o lwgeom_geos_wrapper.cpp
> > lwgeom_geos_wrapper.cpp:11:23: fout: geos/geom.h: Onbekend bestand of map
> --strk;
> geos-devel mailing list
> geos-devel at geos.refractions.net
> http://geos.refractions.net/mailman/listinfo/geos-devel
