[geos-devel] Re: Problems with installation of geos on RedHat 9
(third try, i hope this is text)
strk at refractions.net
Thu May 18 04:46:19 EDT 2006
On Thu, May 18, 2006 at 10:13:25AM +0200, Johan V wrote:
> The only geos-config I have are from the different source directories
> from geos I have, like .../geos-2.2.1/tools/geos-config
> .../geos-3.0.0cvs/tools/geos-config
> .../geos-1.0/tools/geos-config
You should use a geos-config actually *installed*,
not from source.
Either install 3.0.0cvs or install 2.2.1.
--strk;
