[geos-devel] GEOS-3.0.0rc2
Michael Fuhr mike at fuhr.org
Fri Nov 3 23:28:28 EST 2006
On Fri, Nov 03, 2006 at 07:46:37AM -0700, Michael Fuhr wrote:
> On Fri, Nov 03, 2006 at 09:12:06AM +0100, strk at refractions.net wrote:
> > I'd tag rc2 today, unless anyone has pending issues.
> > Scream now or be quiet until rc3 or final :)
> I had build problems on FreeBSD and Solaris a day or two ago but
> I've had little time to investigate or follow the other threads to
> see if there were known problems.  I'll grab the latest code from
> SVN right now and report what happens.
The GEOS build fails if I configure with --enable-python and/or
--enable-ruby; see the attached file for the errors.  Without either
option GEOS builds successfully and passes all regression tests on
FreeBSD 6.2-PRERELEASE i386.
Michael Fuhr
gmake[4]: Entering directory `[...]/swig/python'
if /usr/local/bin/bash ../../libtool --mode=compile --tag=CXX g++ -DHAVE_CONFIG_H -I. -I. -I../../source/headers -I../../source/headers/geos  -I/usr/local/include/python2.4 -I../../capi   -g -O2 -DGEOS_INLINE -Wall -ansi -pedantic -Wno-long-long -MT _geos_la-geos_wrap.lo -MD -MP -MF ".deps/_geos_la-geos_wrap.Tpo" -c -o _geos_la-geos_wrap.lo `test -f 'geos_wrap.cxx' || echo './'`geos_wrap.cxx; \
	then mv -f ".deps/_geos_la-geos_wrap.Tpo" ".deps/_geos_la-geos_wrap.Plo"; else rm -f ".deps/_geos_la-geos_wrap.Tpo"; exit 1; fi
 g++ -DHAVE_CONFIG_H -I. -I. -I../../source/headers -I../../source/headers/geos -I/usr/local/include/python2.4 -I../../capi -g -O2 -DGEOS_INLINE -Wall -ansi -pedantic -Wno-long-long -MT _geos_la-geos_wrap.lo -MD -MP -MF .deps/_geos_la-geos_wrap.Tpo -c geos_wrap.cxx  -fPIC -DPIC -o .libs/_geos_la-geos_wrap.o
geos_wrap.cxx: In function `GeosCoordinateSequence* GeosPoint_getCoordSeq(GeosPoint*)':
geos_wrap.cxx:3413: error: invalid conversion from `const GEOSCoordSequence*' to `GEOSCoordSequence*'
geos_wrap.cxx: In function `GeosCoordinateSequence* GeosLineString_getCoordSeq(GeosLineString*)':
geos_wrap.cxx:3426: error: invalid conversion from `const GEOSCoordSequence*' to `GEOSCoordSequence*'
geos_wrap.cxx: In function `GeosCoordinateSequence* GeosLinearRing_getCoordSeq(GeosLinearRing*)':
geos_wrap.cxx:3439: error: invalid conversion from `const GEOSCoordSequence*' to `GEOSCoordSequence*'
geos_wrap.cxx: In function `GeosGeometry* GeosPolygon_getExteriorRing(GeosPolygon*)':
geos_wrap.cxx:3452: error: invalid conversion from `const GEOSGeometry*' to `GEOSGeometry*'
geos_wrap.cxx: In function `GeosGeometry* GeosPolygon_getInteriorRingN(GeosPolygon*, size_t)':
geos_wrap.cxx:3476: error: invalid conversion from `const GEOSGeometry*' to `GEOSGeometry*'
geos_wrap.cxx: In function `GeosGeometry* GeosGeometryCollection_getGeometryN(GeosGeometryCollection*, size_t)':
geos_wrap.cxx:3489: error: invalid conversion from `const GEOSGeometry*' to `GEOSGeometry*'
gmake[4]: *** [_geos_la-geos_wrap.lo] Error 1
