[geos-devel] GEOS-3.0.0rc2
Paul Ramsey
pramsey at refractions.net
Mon Nov 6 12:01:53 EST 2006
My precise release steps are:
svn export http://svn.refractions.net/geos/tags/[thetag]
./autogen
./configure
make dist
untar dist tarball
./configure
make
make check
If everything works "ok" as far as I can quickly tell visually, I
then copy to the web site.
P
On 6-Nov-06, at 8:08 AM, strk at refractions.net wrote:
> On Mon, Nov 06, 2006 at 08:04:02AM -0800, Paul Ramsey wrote:
>> I ran "make dist" to get the tarball, extracted that and made sure it
>> built, then ran "make distcheck" and saw all the tests run. I was
>> not looking closely at the output, only at general conformance. So
>> "make dist" will need to be fixed to include that file.
> Did you run ./autogen.sh and ./configure again ?
> I'm pretty sure I've fixed this (should be fixed in both trunk
> and tags/3.0.0rc2 )
> --strk;
> geos-devel mailing list
> geos-devel at geos.refractions.net
> http://geos.refractions.net/mailman/listinfo/geos-devel
