[geos-devel] Building GEOS 3.0.0 on windows
Howard Butler hobu at iastate.edu
Fri Nov 10 09:53:15 EST 2006
updated.
Things still say RC1 though... aren't we RC2+?
Howard
At 06:08 AM 11/10/2006, strk at refractions.net wrote:
>As I said (or left as intended) I'm not a win32 user.
>Anyway, what I've understood is that geos_c.h.vc is just a copy
>of geos_c.h.in with the version strings defined correctly.
>Try that (copy geos_c.h.in and manually substitute version strings, look
>in configure.in for values)
>--strk;
>On Fri, Nov 10, 2006 at 11:37:27AM +0000, Mir Hassan Ali wrote:
> > I am using the nmake command and the Makefile.vc under the source folder. I
> > think that makes use of the geos_c.h.vc file. Here is a small extract from
> > my cmd window.
> > nmake -f makefile.vc
> > Microsoft (R) Program Maintenance Utility Version 7.10.3077
> > Copyright (C) Microsoft Corporation.  All rights reserved.
> >        copy ..\capi\geos_c.h.vc ..\capi\geos_c.h
> >        1 file(s) copied.
> >        cl -Iheaders /MD /GR /O2 /D "NDEBUG" /nologo  /D "NOMINMAX" /D
> > "WIN32_LE
> > AN_AND_MEAN" /D "NOGDI"  /GX /c ..\capi\geos_c.cpp /Fo..\capi\geos_c.obj
> > geos_c.cpp
> > c:\GEOS\trunk\capi\geos_c.h(49) : warning C4005: 'GEOS_VERSION_PATCH' :
> > macro redefi
> > nition
> >        headers\geos\version.h(6) : see previous definition of
> > 'GEOS_VERSION_PAT
> > CH'
> > c:\GEOS\trunk\capi\geos_c.h(50) : warning C4005: 'GEOS_VERSION' : macro
> > redefinition
> >        headers\geos\version.h(7) : see previous definition of
> > 'GEOS_VERSION'
> > ..\capi\geos_c.cpp(123) : error C2733: second C linkage of overloaded
> > function '
> > GEOSDisjoint' not allowed
> >        ..\capi\geos_c.cpp(122) : see declaration of 'GEOSDisjoint'
> > ..\capi\geos_c.cpp(144) : error C2733: second C linkage of overloaded
> > function '
> > GEOSTouches' not allowed
> > Thanks
> > Mir
> > On 11/10/06, strk at refractions.net <strk at refractions.net> wrote:
> > >On Fri, Nov 10, 2006 at 11:18:53AM +0000, Mir Hassan Ali wrote:
> > >> Hi
> > >> I have a small GIS application in C# that uses GDAL library. But now I
> > >need
> > >> some functionality provided by GEOS, so I need to build GEOS and then
> > >> rebuild GDAL with GEOS support. Is there any older version of GEOS that
> > >i
> > >> can use or perhaps any other way you can think of.
> > >The easiest way is just fix the geos_c.h.vc, probably.
> > >is that what you use for building ?
> > >--strk
> > >_______________________________________________
> > >geos-devel mailing list
> > >geos-devel at geos.refractions.net
> > >http://geos.refractions.net/mailman/listinfo/geos-devel
>  /"\    ASCII Ribbon Campaign
>  \ /    Respect for low technology.
>   X     Keep e-mail messages readable by any computer system.
>  / \    Keep it ASCII.
