[geos-devel] Building GEOS 3.0.0 on windows
strk at refractions.net strk at refractions.net
Fri Nov 10 12:55:58 EST 2006
On Fri, Nov 10, 2006 at 09:52:54AM -0800, Paul Ramsey wrote:
> I just committed that change, it's done.
Wow, that was *much* simpler than I've been thinkgin :P
Could you please update the ChangeLog file too ?
Thanks.
--strk;
> On 10-Nov-06, at 9:51 AM, strk at refractions.net wrote:
> >On Fri, Nov 10, 2006 at 09:46:36AM -0800, Paul Ramsey wrote:
> >>When I run autogen.sh I get the right versions into configure.  When
> >>I run configure I get the right versions into the .h and (now) .h.vc
> >>files.
> >.h.vc files are not automatically generated, if you get correct
> >versions
> >there that's due to hobu commits. Since we need to run ./autogen.sh
> >and
> >./configure to use the 'make dist' rule I guess having the .h.vc files
> >created by ./configure (or a dist-hook) is a viable solution.
> >Win32 volunteers ? (no, don't need to make a batch command, just a
> >shell
> >script)
> >--strk;
