[geos-devel] C API busted for Windows
Paul Ramsey
pramsey at refractions.net
Sat Nov 11 00:43:20 EST 2006
Sorry, I must have copied the vanilla .h file over the .vc file at
some point while juggling things to get the .vc into a .in where it
would get versions macro-substituted. I've dredged the original back
out of the revision. Getting the .vc from the .vc.in does require a
'make dist' on a gnu system first. The svn snapshot will have the
generated file.
P
On 10-Nov-06, at 1:50 PM, Howard Butler wrote:
> D:\cvs\PCL\PCL-Core>python setup.py build
> running build
> running build_py
> running build_ext
> building 'cartography.geometry._geom' extension
> C:\Program Files\Microsoft Visual Studio .NET 2003\Vc7\bin\cl.exe /
> c /nologo /Ox
> /MD /W3 /GX /DNDEBUG -Id:\cvs\buildkit\geos\capi -Id:\cvs\buildkit
> \proj-4.4.9\s
> rc -IC:\Python24\include -IC:\Python24\PC /Tccartography/geometry/
> _geommodule.c
> /Fobuild\temp.win32-2.4\Release\cartography/geometry/_geommodule.obj
> _geommodule.c
> d:\cvs\buildkit\geos\capi\geos_c.h(134) : error C2059: syntax
> error : 'type'
> d:\cvs\buildkit\geos\capi\geos_c.h(151) : error C2059: syntax
> error : 'type'
> d:\cvs\buildkit\geos\capi\geos_c.h(154) : error C2059: syntax
> error : 'type'
> d:\cvs\buildkit\geos\capi\geos_c.h(168) : error C2059: syntax
> error : 'type'
> d:\cvs\buildkit\geos\capi\geos_c.h(174) : error C2059: syntax
> error : 'type'
> d:\cvs\buildkit\geos\capi\geos_c.h(225) : error C2059: syntax
> error : 'type'
> d:\cvs\buildkit\geos\capi\geos_c.h(226) : error C2059: syntax
> error : 'type'
> d:\cvs\buildkit\geos\capi\geos_c.h(227) : error C2059: syntax
> error : 'type'
> d:\cvs\buildkit\geos\capi\geos_c.h(234) : error C2059: syntax
> error : 'type'
> d:\cvs\buildkit\geos\capi\geos_c.h(236) : error C2059: syntax
> error : 'type'
> d:\cvs\buildkit\geos\capi\geos_c.h(239) : error C2059: syntax
> error : 'type'
> d:\cvs\buildkit\geos\capi\geos_c.h(256) : error C2059: syntax
> error : 'type'
> d:\cvs\buildkit\geos\capi\geos_c.h(257) : error C2059: syntax
> error : 'type'
> d:\cvs\buildkit\geos\capi\geos_c.h(258) : error C2059: syntax
> error : 'type'
> d:\cvs\buildkit\geos\capi\geos_c.h(260) : error C2059: syntax
> error : 'type'
> d:\cvs\buildkit\geos\capi\geos_c.h(261) : error C2059: syntax
> error : 'type'
> d:\cvs\buildkit\geos\capi\geos_c.h(262) : error C2059: syntax
> error : 'type'
> d:\cvs\buildkit\geos\capi\geos_c.h(264) : error C2059: syntax
> error : 'type'
> d:\cvs\buildkit\geos\capi\geos_c.h(265) : error C2059: syntax
> error : 'type'
> d:\cvs\buildkit\geos\capi\geos_c.h(266) : error C2059: syntax
> error : 'type'
> d:\cvs\buildkit\geos\capi\geos_c.h(267) : error C2059: syntax
> error : 'type'
> d:\cvs\buildkit\geos\capi\geos_c.h(274) : error C2059: syntax
> error : 'type'
> d:\cvs\buildkit\geos\capi\geos_c.h(277) : error C2059: syntax
> error : 'type'
> d:\cvs\buildkit\geos\capi\geos_c.h(278) : error C2059: syntax
> error : 'type'
> d:\cvs\buildkit\geos\capi\geos_c.h(279) : error C2059: syntax
> error : 'type'
> d:\cvs\buildkit\geos\capi\geos_c.h(344) : error C2059: syntax
> error : 'type'
> d:\cvs\buildkit\geos\capi\geos_c.h(357) : error C2059: syntax
> error : 'type'
> d:\cvs\buildkit\geos\capi\geos_c.h(364) : error C2059: syntax
> error : 'type'
> d:\cvs\buildkit\geos\capi\geos_c.h(373) : error C2059: syntax
> error : 'type'
> cartography\geometry\_geommodule.c(100) : warning C4013:
> 'GEOSCoordSeq_create' undefined; assuming extern returning int
> cartography\geometry\_geommodule.c(125) : warning C4013:
> 'GEOSCoordSeq_clone' undefined; assuming extern returning int
> cartography\geometry\_geommodule.c(125) : warning C4047: '=' :
> 'GEOSCoordSeq' differs in levels of indirection from 'int'
> cartography\geometry\_geommodule.c(179) : warning C4018: '>=' :
> signed/unsigned mismatch
> cartography\geometry\_geommodule.c(215) : warning C4018: '>=' :
> cartography\geometry\_geommodule.c(251) : warning C4018: '>=' :
> cartography\geometry\_geommodule.c(284) : warning C4018: '>=' :
> cartography\geometry\_geommodule.c(319) : warning C4018: '>=' :
> cartography\geometry\_geommodule.c(354) : warning C4018: '>=' :
> cartography\geometry\_geommodule.c(482) : warning C4013:
> 'GEOSGeom_clone' undefined; assuming extern returning int
> cartography\geometry\_geommodule.c(482) : warning C4047: '=' :
> 'GEOSGeom' differs in levels of indirection from 'int'
> cartography\geometry\_geommodule.c(499) : warning C4013:
> 'GEOSGeomFromWKB_buf' undefined; assuming extern returning int
> cartography\geometry\_geommodule.c(499) : warning C4047: '=' :
> cartography\geometry\_geommodule.c(520) : warning C4047: '=' :
> cartography\geometry\_geommodule.c(546) : warning C4013:
> 'GEOSGeomFromWKT' undefined; assuming extern returning int
> cartography\geometry\_geommodule.c(546) : warning C4047: '=' :
> cartography\geometry\_geommodule.c(566) : warning C4047: '=' :
> cartography\geometry\_geommodule.c(613) : warning C4013:
> 'GEOSGeom_createPoint' undefined; assuming extern returning int
> cartography\geometry\_geommodule.c(613) : warning C4047: '=' :
> cartography\geometry\_geommodule.c(616) : warning C4013:
> 'GEOSGeom_createLineString' undefined; assuming extern returning int
> cartography\geometry\_geommodule.c(616) : warning C4047: '=' :
> cartography\geometry\_geommodule.c(619) : warning C4013:
> 'GEOSGeom_createLinearRing' undefined; assuming extern returning int
> cartography\geometry\_geommodule.c(619) : warning C4047: '=' :
> cartography\geometry\_geommodule.c(660) : warning C4047: '=' :
> cartography\geometry\_geommodule.c(675) : warning C4047: '=' :
> cartography\geometry\_geommodule.c(678) : warning C4047: '=' :
> cartography\geometry\_geommodule.c(681) : warning C4047: '=' :
> cartography\geometry\_geommodule.c(721) : warning C4047: '=' :
> cartography\geometry\_geommodule.c(757) : warning C4013:
> 'GEOSGeom_createPolygon' undefined; assuming extern returning int
> cartography\geometry\_geommodule.c(757) : warning C4047: '=' :
> cartography\geometry\_geommodule.c(776) : warning C4047: '=' :
> cartography\geometry\_geommodule.c(823) : warning C4013:
> 'GEOSGeom_createCollection' undefined; assuming extern returning int
> cartography\geometry\_geommodule.c(823) : warning C4047: '=' :
> cartography\geometry\_geommodule.c(942) : warning C4013:
> 'GEOSEnvelope' undefined; assuming extern returning int
> cartography\geometry\_geommodule.c(942) : warning C4047: '=' :
> cartography\geometry\_geommodule.c(1272) : warning C4013:
> 'GEOSIntersection' undefined; assuming extern returning int
> cartography\geometry\_geommodule.c(1272) : warning C4047: '=' :
> cartography\geometry\_geommodule.c(1291) : warning C4013:
> 'GEOSBuffer' undefined; assuming extern returning int
> cartography\geometry\_geommodule.c(1291) : warning C4047: '=' :
> cartography\geometry\_geommodule.c(1305) : warning C4013:
> 'GEOSConvexHull' undefined; assuming extern returning int
> cartography\geometry\_geommodule.c(1305) : warning C4047: '=' :
> cartography\geometry\_geommodule.c(1326) : warning C4013:
> 'GEOSDifference' undefined; assuming extern returning int
> cartography\geometry\_geommodule.c(1326) : warning C4047: '=' :
> cartography\geometry\_geommodule.c(1347) : warning C4013:
> 'GEOSSymDifference' undefined; assuming extern returning int
> cartography\geometry\_geommodule.c(1347) : warning C4047: '=' :
> cartography\geometry\_geommodule.c(1362) : warning C4013:
> 'GEOSBoundary' undefined; assuming extern returning int
> cartography\geometry\_geommodule.c(1362) : warning C4047: '=' :
> cartography\geometry\_geommodule.c(1383) : warning C4013:
> 'GEOSUnion' undefined; assuming extern returning int
> cartography\geometry\_geommodule.c(1383) : warning C4047: '=' :
> cartography\geometry\_geommodule.c(1398) : warning C4013:
> 'GEOSPointOnSurface' undefined; assuming extern returning int
> cartography\geometry\_geommodule.c(1398) : warning C4047: '=' :
> cartography\geometry\_geommodule.c(1413) : warning C4013:
> 'GEOSGetCentroid' undefined; assuming extern returning int
> cartography\geometry\_geommodule.c(1413) : warning C4047: '=' :
> cartography\geometry\_geommodule.c(1694) : warning C4013:
> 'GEOSGetGeometryN' undefined; assuming extern returning int
> cartography\geometry\_geommodule.c(1694) : warning C4047: '=' :
> cartography\geometry\_geommodule.c(1723) : warning C4013:
> 'GEOSGetExteriorRing'undefined; assuming extern returning int
> cartography\geometry\_geommodule.c(1723) : warning C4047: '=' :
> cartography\geometry\_geommodule.c(1785) : warning C4013:
> 'GEOSGetInteriorRingN' undefined; assuming extern returning int
> cartography\geometry\_geommodule.c(1785) : warning C4047: '=' :
> cartography\geometry\_geommodule.c(1806) : warning C4013:
> 'GEOSGeom_getCoordSeq' undefined; assuming extern returning int
> cartography\geometry\_geommodule.c(1806) : warning C4047: '=' :
> cartography\geometry\_geommodule.c(1835) : warning C4018: '<' :
> cartography\geometry\_geommodule.c(1855) : warning C4018: '<' :
> cartography\geometry\_geommodule.c(1923) : warning C4047: '=' :
> cartography\geometry\_geommodule.c(1927) : warning C4047: '=' :
> cartography\geometry\_geommodule.c(1931) : warning C4047: '=' :
> cartography\geometry\_geommodule.c(1935) : warning C4047: '=' :
> cartography\geometry\_geommodule.c(1936) : warning C4047: '=' :
> cartography\geometry\_geommodule.c(1942) : warning C4047: '=' :
> cartography\geometry\_geommodule.c(1943) : warning C4047: '=' :
> cartography\geometry\_geommodule.c(1951) : warning C4047: '=' :
> cartography\geometry\_geommodule.c(1952) : warning C4047: '=' :
> cartography\geometry\_geommodule.c(1960) : warning C4047: '=' :
> cartography\geometry\_geommodule.c(1961) : warning C4047: '=' :
> cartography\geometry\_geommodule.c(1969) : warning C4047: '=' :
> cartography\geometry\_geommodule.c(1970) : warning C4047: '=' :
> cartography\geometry\_geommodule.c(1971) : warning C4047: '=' :
> cartography\geometry\_geommodule.c(1976) : warning C4047: '=' :
> cartography\geometry\_geommodule.c(1977) : warning C4047: '=' :
> cartography\geometry\_geommodule.c(1986) : warning C4047: '=' :
> cartography\geometry\_geommodule.c(1989) : warning C4047: '=' :
> cartography\geometry\_geommodule.c(1994) : warning C4047: '=' :
> cartography\geometry\_geommodule.c(1995) : warning C4047: '=' :
> cartography\geometry\_geommodule.c(2000) : warning C4047: '=' :
> cartography\geometry\_geommodule.c(2001) : warning C4047: '=' :
> The new header file does this in many places which is not valid:
> extern GEOSGeometry* GEOS_DLL GEOSGeomFromWKB_buf(const unsigned
> char *wkb, size_t size);
> It needs to be (or something like it):
> extern GEOS_DLL GEOSGeometry* GEOSGeomFromWKB_buf(const unsigned
> Input on the signed/unsigned warnings and what's causing them would
> be appreciated. This module (PCL) wasn't causing them before the
> latest updates to the headers.
> Howard
> geos-devel mailing list
> geos-devel at geos.refractions.net
> http://geos.refractions.net/mailman/listinfo/geos-devel
