[geos-devel] Building GEOS with GDAL
Mir Hassan Ali mirhassanali at gmail.com
Tue Nov 14 12:00:54 EST 2006
Hi
Do I need to include GEOS_DLL before the return type in all the function
definitions?
If i do so then the previous errors are removed but I get new errors:
shpopen.c
..\math.h(20) : error C2061: syntax error : identifier 'geos'
..\math.h(20) : error C2059: syntax error : ';'
..\math.h(20) : error C2449: found '{' at file scope (missing function
header?)
..\math.h(42) : error C2059: syntax error : '}'
C:\Program Files\Microsoft Visual Studio .NET 2003\Vc7\include\cstdio(17) :
erro
r C2143: syntax error : missing '{' before ':'
erro
r C2059: syntax error : ':'
erro
erro
erro
erro
C:\Program Files\Microsoft Visual Studio .NET 2003\Vc7\include\cstdio(18) :
erro
erro
erro
erro
erro
erro
C:\Program Files\Microsoft Visual Studio .NET 2003\Vc7\include\cstdio(19) :
erro
erro
erro
erro
erro
erro
C:\Program Files\Microsoft Visual Studio .NET 2003\Vc7\include\cstdio(20) :
erro
erro
erro
erro
erro
erro
C:\Program Files\Microsoft Visual Studio .NET 2003\Vc7\include\cstdio(21) :
erro
erro
erro
erro
erro
erro
C:\Program Files\Microsoft Visual Studio .NET 2003\Vc7\include\cstdio(22) :
erro
erro
erro
erro
erro
erro
C:\Program Files\Microsoft Visual Studio .NET 2003\Vc7\include\cstdio(23) :
erro
erro
erro
erro
erro
erro
C:\Program Files\Microsoft Visual Studio .NET 2003\Vc7\include\cstdio(24) :
erro
erro
erro
erro
erro
erro
C:\Program Files\Microsoft Visual Studio .NET 2003\Vc7\include\cstdio(25) :
erro
erro
erro
erro
C:\Program Files\Microsoft Visual Studio .NET 2003\Vc7\include\cstdio(26) :
erro
erro
erro
erro
C:\Program Files\Microsoft Visual Studio .NET 2003\Vc7\include\cstdio(27) :
erro
erro
erro
erro
erro
erro
C:\Program Files\Microsoft Visual Studio .NET 2003\Vc7\include\cstdio(28) :
erro
erro
erro
erro
erro
erro
C:\Program Files\Microsoft Visual Studio .NET 2003\Vc7\include\cstdio(29) :
erro
erro
erro
erro
erro
erro
C:\Program Files\Microsoft Visual Studio .NET 2003\Vc7\include\cstdio(30) :
erro
erro
erro
erro
erro
erro
C:\Program Files\Microsoft Visual Studio .NET 2003\Vc7\include\cstdio(31) :
erro
erro
erro
erro
Any ideas?
Best Regards
Mir
On 11/14/06, Howard Butler <hobu at iastate.edu> wrote:
> http://lists.refractions.net/pipermail/geos-devel/2006-November/002670.html
> At 07:00 AM 11/14/2006, strk at refractions.net wrote:
> >On Tue, Nov 14, 2006 at 12:50:33PM +0000, Mir Hassan Ali wrote:
> > > Hi
> > > I am also getting these warnings for geos_c.h file. Are these of any
> > > significance?
> >mmm... maybe the type specifier is just placed in the wrong
> >way:
> >133: extern GEOSGeometry* GEOS_DLL GEOSGeomFromWKT(const char *wkt);
> >134: extern char GEOS_DLL *GEOSGeomToWKT(const GEOSGeometry* g);
> >Since you don't get a warning on 134 I suppose it should be:
> >134: extern char * GEOS_DLL GEOSGeomToWKT(const GEOSGeometry* g);
> >Can you try ?
> >--strk;
> > > ..\ogr\geos_c.h(134) : warning C4518: '__declspec(dllexport ) ' :
> > > storage-class or type specifier(s) unexpected here; ignored
> > > ..\ogr\geos_c.h(151) : warning C4518: '__declspec(dllexport ) ' :
> > > ..\ogr\geos_c.h(154) : warning C4518: '__declspec(dllexport ) ' :
> > > ..\ogr\geos_c.h(168) : warning C4518: '__declspec(dllexport ) ' :
> > > ..\ogr\geos_c.h(174) : warning C4518: '__declspec(dllexport ) ' :
> > > ..\ogr\geos_c.h(225) : warning C4518: '__declspec(dllexport ) ' :
> > > ..\ogr\geos_c.h(226) : warning C4518: '__declspec(dllexport ) ' :
> > > ..\ogr\geos_c.h(227) : warning C4518: '__declspec(dllexport ) ' :
> > > ..\ogr\geos_c.h(234) : warning C4518: '__declspec(dllexport ) ' :
> > > ..\ogr\geos_c.h(236) : warning C4518: '__declspec(dllexport ) ' :
> > > ..\ogr\geos_c.h(239) : warning C4518: '__declspec(dllexport ) ' :
> > > ..\ogr\geos_c.h(256) : warning C4518: '__declspec(dllexport ) ' :
> > > ..\ogr\geos_c.h(257) : warning C4518: '__declspec(dllexport ) ' :
> > > ..\ogr\geos_c.h(258) : warning C4518: '__declspec(dllexport ) ' :
> > > ..\ogr\geos_c.h(260) : warning C4518: '__declspec(dllexport ) ' :
> > > ..\ogr\geos_c.h(261) : warning C4518: '__declspec(dllexport ) ' :
> > > ..\ogr\geos_c.h(262) : warning C4518: '__declspec(dllexport ) ' :
> > > ..\ogr\geos_c.h(264) : warning C4518: '__declspec(dllexport ) ' :
> > > ..\ogr\geos_c.h(265) : warning C4518: '__declspec(dllexport ) ' :
> > > ..\ogr\geos_c.h(266) : warning C4518: '__declspec(dllexport ) ' :
> > > ..\ogr\geos_c.h(267) : warning C4518: '__declspec(dllexport ) ' :
> > > ..\ogr\geos_c.h(274) : warning C4518: '__declspec(dllexport ) ' :
> > > ..\ogr\geos_c.h(277) : warning C4518: '__declspec(dllexport ) ' :
> > > ..\ogr\geos_c.h(278) : warning C4518: '__declspec(dllexport ) ' :
> > > ..\ogr\geos_c.h(279) : warning C4518: '__declspec(dllexport ) ' :
> > > ..\ogr\geos_c.h(344) : warning C4518: '__declspec(dllexport ) ' :
> > > ..\ogr\geos_c.h(357) : warning C4518: '__declspec(dllexport ) ' :
> > > ..\ogr\geos_c.h(364) : warning C4518: '__declspec(dllexport ) ' :
> > > ..\ogr\geos_c.h(373) : warning C4518: '__declspec(dllexport ) ' :
> > > I am still unable to build GDAL with GEOS.
> > > Best Regards
> > > Mir
> > > On 11/14/06, strk at refractions.net <strk at refractions.net> wrote:
> > > >Argh.. sounds related to latest 'const-correctness' or 'integer
> > > >signedness'
> > > >changes in the CAPI header file, is this possible ?
> > > >I'm not an expert of the __declspec(dllexport) thing ...
> > > >--strk;
> > > >On Mon, Nov 13, 2006 at 05:13:30PM +0000, Mir Hassan Ali wrote:
> > > >> Hi Frank,
> > > >> I downloaded the GDAL snapshot on 6th November 2006, so i assume it
> > > >includes
> > > >> the latest changes. When I compile it without the GEOS support, i.ethe
> > > >> following lines are commented in the nmake.opt file are commented:
> > > >> GEOS_CFLAGS = -IC:/GEOS/trunk/capi -DHAVE_GEOS
> > > >> GEOS_LIB = C:/GEOS/trunk/source/geos_c_i.lib
> > > >> But when I uncomment these lines and try to build the API it gives
> me
> > > >the
> > > >> following link errors:
> > > >> Creating library gdal_i.lib and object gdal_i.exp
> > > >> ogr.lib(ogrgeometry.obj) : error LNK2019: unresolved external
> symbol
> > > >> _GEOSGeomFr
> > > >> omWKB_buf referenced in function "public: virtual struct GEOSGeom_t
> > > >> __thiscall
> > > >> OGRGeometry::exportToGEOS(void)const " (
> > > >> ?exportToGEOS at OGRGeometry@@UBEPAUGEOSGe
> > > >> om_t@@XZ)
> symbol
> > > >> _GEOSConvex
> > > >> Hull referenced in function "public: virtual class OGRGeometry *
> > > >__thiscall
> > > >> OGRG
> > > >> eometry::ConvexHull(void)const " (?ConvexHull at OGRGeometry@@
> UBEPAV1 at XZ )
> > > >> ogr.lib(ogrgeometry.obj ) : error LNK2019: unresolved external
> symbol
> > > >> _GEOSBounda
> > > >> ry referenced in function "public: virtual class OGRGeometry *
> > > >__thiscall
> > > >> OGRGeo
> > > >> metry::getBoundary(void)const " ( ?getBoundary at OGRGeometry@@
> UBEPAV1 at XZ)
> symbol
> > > >> _GEOSBuffer
> __thiscall
> > > >> OGRGeome
> > > >> try::Buffer(double,int)const " ( ?Buffer at OGRGeometry@@UBEPAV1 at NH@Z)
> symbol
> > > >> _GEOSInters
> > > >> ection referenced in function "public: virtual class OGRGeometry *
> > > >> __thiscall OG
> > > >> RGeometry::Intersection(class OGRGeometry const *)const "
> > > >> (?Intersection at OGRGeom
> > > >> etry@@UBEPAV1 at PBV1@@Z)
> symbol
> > > >> _GEOSUnion
> __thiscall
> > > >> OGRGeomet
> > > >> ry::Union(class OGRGeometry const *)const "
> > > >> (?Union at OGRGeometry@@UBEPAV1 at PBV1@@Z
> symbol
> > > >> _GEOSDiffer
> > > >> ence referenced in function "public: virtual class OGRGeometry *
> > > >__thiscall
> > > >> OGRG
> > > >> eometry::Difference(class OGRGeometry const *)const " (
> > > >> ?Difference at OGRGeometry@@
> > > >> UBEPAV1 at PBV1@@Z)
> symbol
> > > >> _GEOSSymDif
> > > >> ference referenced in function "public: virtual class OGRGeometry *
> > > >> __thiscall O
> > > >> GRGeometry::SymmetricDifference(class OGRGeometry const *)const "
> > > >> (?SymmetricDif
> > > >> ference at OGRGeometry@@UBEPAV1 at PBV1@@Z)
> > > >> ogr.lib(ogrpolygon.obj) : error LNK2019: unresolved external symbol
> > > >> _GEOSGetCent
> > > >> roid referenced in function "public: virtual int __thiscall
> > > >> OGRPolygon::Centroid
> > > >> (class OGRPoint *)const " (
> ?Centroid at OGRPolygon@@UBEHPAVOGRPoint@@@Z)
> > > >> gdal13.dll : fatal error LNK1120: 9 unresolved externals
> > > >> NMAKE : fatal error U1077: 'link' : return code '0x460'
> > > >> Stop.
> > > >> Is there something else that I need to do in addition to the
> changes
> > > >> mentioned above to the nmake.opt file. Please note that I am using
> the
> > > >> latest version of the GEOS API. I checked it out from the
> subversion
> > > >trunk
> > > >> and built it. It builds fine without any errors or warnings.
> > > >> Best Regards
> > > >_______________________________________________
> > > >geos-devel mailing list
> > > >geos-devel at geos.refractions.net
> > > >http://geos.refractions.net/mailman/listinfo/geos-devel
> >  /"\    ASCII Ribbon Campaign
> >  \ /    Respect for low technology.
> >   X     Keep e-mail messages readable by any computer system.
> >  / \    Keep it ASCII.
URL: http://lists.osgeo.org/pipermail/geos-devel/attachments/20061114/a4c72440/attachment.html
