[geos-devel] strange test case
strk at refractions.net
Wed Nov 15 05:38:42 EST 2006
Carl, I think I fixed this already. Can you confirm
you don't get an assertion failure with rc2 ?
--strk;
On Tue, Nov 14, 2006 at 02:46:18PM -0500, Carl Anderson wrote:
> strk,
> I have finally isolated an example that generates the assertion error.
> I get the error:
> bufferOriginalPrecision failed, trying with reduced precision
> Scaler: offsetX,Y: 0,0 scaleFactor: 25
> XMLTester: ../source/headers/geos/noding/SegmentString.h:167: void
> geos::noding::SegmentString::testInvariant() const: Assertion
> `pts->size() == npts' failed.
> Abort
> The error occurs on Intel PIII and P4 chips, but have not been able to
> produce the error in AMD Athlon chips.
> I used gcc 4.1.1 with the GEOS default -O2 flags.
> It may or may not produce an error for you.
> run the attached into XMLTester.
> BTW this example is not a valid geometry. I was created through a
> series of PostGIS operations,
> Difference() and Simplify().
> C.
> Carl Anderson
> GIS Manager Fulton County, Georgia
> carl.anderson at co.fulton.ga.us
> 404.730.8026
> geos-devel mailing list
> geos-devel at geos.refractions.net
> http://geos.refractions.net/mailman/listinfo/geos-devel
/"\ ASCII Ribbon Campaign
\ / Respect for low technology.
X Keep e-mail messages readable by any computer system.
/ \ Keep it ASCII.
