[geos-devel] Building GEOS
Mir Hassan Ali
mirhassanali at gmail.com
Wed Nov 15 06:04:42 EST 2006
Does anyone have any idea, how to build GEOS snapshot using nmake?
OR
Can I get pre-built binaries of latest GEOS from somewhere?
Best Regards
Mir
On 11/15/06, strk at refractions.net <strk at refractions.net> wrote:
> On Wed, Nov 15, 2006 at 10:08:58AM +0000, Mir Hassan Ali wrote:
> > Hi
> > I have checked out the latest trunk of GEOS, but when I try to build it
> > using 'nmake' I get the following error:
> > NMAKE : fatal error U1073: don't know how to make '../capi/geos_c.h.vc'
> > Stop.
> > I noticed that there is no 'geos_c.h.vc' file inside capi folder,
> instead
> > there is 'geos_c.h.vc.in'. Do I need to do something before using nmake.
> geos_c.h.vc is created from geos_c.h.vc.in by ./configure.
> I don't know anything about nmake to help you with that.
> If use of 'nmake' does *not* require run of ./configure then I guess
> a nmake rule must be added to produce that file by itself.
> --strk;
> geos-devel mailing list
> geos-devel at geos.refractions.net
> http://geos.refractions.net/mailman/listinfo/geos-devel
URL: http://lists.osgeo.org/pipermail/geos-devel/attachments/20061115/564d6355/attachment.html
