[geos-devel] [Konstantin.Baumann@hpi.uni-potsdam.de: geos_c.cpp compile problems with VS 2005]
strk at refractions.net strk at refractions.net
Thu Nov 16 06:04:41 EST 2006
Wow, there are a lots of win users out there...
geos_c.h.vc AND version.h.vc in current TRUNK have
been obsoleted, the Makefile.vc reflect this by directly
including geos_c.h and version.h instead, which are created
by ./configure.
Note that ./configure itself is *not* in the SVN repository, and
will be created by running ./autogen.sh
If you can't run ./autogen.sh, that means your development
environment does not meet GEOS development environment requirements
for repository-level hacking.
In that case, you can still hack GEOS by grabbing an SVN snapshot,
which *should* include geos_c.h and version.h by now.
Note that the SVN snapshot also includes the ./configure script, so
you can also modify the .h.in files and rerun that if working
on some bugfix.
If you can't run ./configure, that means your development
for release-level hacking.
In that case, you can still hack GEOS by manually copying the .h.in
files into .h and manually update the *VERSION* flags.
If you think this process is too annoying consider using a POSIX system
for development.
Thanks.
--strk;
On Thu, Nov 16, 2006 at 10:42:51AM +0000, Pierre viallet wrote:
> i've run ./configure (using MinGW) on fresh svn (revison 1916)
> and then run nmake /f makefile.vc
> I've copied capi_c.h into capi.h.vc.  (capi/geos_c.h.vc seems to be missing in trunk !?!   does it be generated by configure?.)
> Here it is now my pb :
> capi\geos_c.h(127) : error C2059: syntax error : '__declspec(dllexport)'
> ----- Message d'origine ----
> De : "strk at refractions.net" <strk at refractions.net>
> À : geos-devel at geos.refractions.net
> Envoyé le : Jeudi, 16 Novembre 2006, 10h03mn 17s
> Objet : Re: [geos-devel] [Konstantin.Baumann at hpi.uni-potsdam.de: geos_c.cpp compile problems with VS 2005]
> Please try with current TRUNC, runnign ./configure.
> Or fetching the snapshot on the website.
> --strk;
> On Thu, Nov 16, 2006 at 08:48:14AM +0000, Pierre viallet wrote:
> > Yes, i've got this problem using MSVC2005 geos_c.h.vc as geos.h.
> > Regards,
> > PS:
> > on geos_c.vc :
> > extern char GEOS_DLL GEOSDisjoint(const GEOSGeom g1, const GEOSGeom g2);
> > on geos_c.cpp:
> > char
> > GEOSDisjoint(const Geometry *g1, const Geometry *g2)
> > ___________________________________________________________________________
> > Yahoo! Mail réinvente le mail ! Découvrez le nouveau Yahoo! Mail et son interface révolutionnaire.
> > http://fr.mail.yahoo.com
> > geos-devel mailing list
> > http://geos.refractions.net/mailman/listinfo/geos-devel
> /"\    ASCII Ribbon Campaign
> \ /    Respect for low technology.
>   X     Keep e-mail messages readable by any computer system.
> / \    Keep it ASCII.
 / \    Keep it ASCII.
