[geos-devel] Exceptions and CAPI
Olivier Bedel
obedel at irisa.fr
Mon Nov 27 12:29:54 EST 2006
Hi all members of the list,
I try to handle exception with the CAPI. I use the GEOSGeomFromWKT
function and I want to avoid segmentation fault when a wrong wkt string
is given as a parameter. Reading the comments in geos_c.h, I expected
this function return a NULL pointer when an exception was raised, but
strangely, it seems that he seg fault happens in the function call. So I
get no return values and I can't handle exceptions.
Here is a simple example of what I want to do:
GEOSGeometry *g;
g = GEOSGeomFromWKT("POLYGON(0.0 0.0, 1.0 1.0, 2.0 2.0, 0.0 0.0))");
if (g==NULL)
fprintf(stderr,"g is not a valid geometry\n");
Do I miss something ?
Thanks in advance,
Olivier.
