[geos-devel] troubles understanding GEOS
Markus Schaber
schabi at logix-tt.com
Wed Nov 29 04:18:22 EST 2006
Hi, Tobias,
Tobias Nothdurft wrote:
>> Databases provide you with a higher layer of abstraction. With PostGIS,
>> you can e. G. load all your linestrings in a table, create an
>> geometrical index on it, and then easily and efficiently fetch all
>> linestrings in a specific area with a query like:
>> SELECT * FROM mytable WHERE the_geom && 'BOX(1 2,3 4)'::box2d;
> That sounds nice.
> So I can use a SQL commando like the above instead of using a quadtree?
When you use PostGIS, yes.
You've got the power and drawbacks of a full relational database.
The query above simply fetches all geometries whose bounding box
overlaps with the given region. More complex queries and operations are
possible.
PostGIS includes a GIST-based R-Tree implementation, so you can add a
spatial index to your data table which speeds up the query, especially
when only a small fraction of the data is actually matching your condition.
HTH,
Markus
Markus Schaber | Logical Tracking&Tracing International AG
Dipl. Inf. | Software Development GIS
Fight against software patents in Europe! www.ffii.org
www.nosoftwarepatents.org
Desc: OpenPGP digital signature
Url : http://lists.osgeo.org/pipermail/geos-devel/attachments/20061129/c7c6fef6/signature.bin
