[geos-devel] Open issues
Markus Schaber
schabi at logix-tt.com
Mon Oct 30 06:24:16 EST 2006
I'm just trying to summarize our discussion on #postgis.
The open issues for GEOS seem to be:
- The enum GEOSGeomTypeId was renamed to GEOSGeomTypes - this
might break compatibility with clients. Why was it done, and should
it be reverted?
- Our "typedef struct GEOSGeom_t *GEOSGeom;" used in function arguments
as "const GEOSGeom" actually defines an unmodifiable Pointer to a
modifiable Geometry. This is the reason for those "type qualifiers
ignored on return type" warnings.
Possible solutions:
- Include the "const" into the typedef, as the C-API does not expose
any in-place modificators.
- Remove the "*" from the typedef, and declare the Pointers explicitly
in the function definitions
We will have to dig into whether this might break any clients.
- The same for "typedef struct GEOSCoordSeq_t *GEOSCoordSeq;".
- Missing regression test for Polygonizer.
- Inclusion of capi/geostest into "make check".
Some of this issues might be critical enough to block 3.0.0 final.
I hope that I did not miss something.
HTH,
Markus
Markus Schaber | Logical Tracking&Tracing International AG
Dipl. Inf. | Software Development GIS
Fight against software patents in Europe! www.ffii.org
www.nosoftwarepatents.org
