[geos-devel] can i ask questions related to postgresql spatial queries
Paul Ramsey pramsey at refractions.net
Mon Oct 30 14:59:35 EST 2006
Vamsee, this is more a PostGIS question than GEOS question so follow-
up on postgis-users.
The query looks correct to me, what makes you think it is wrong?
The 9999 issue is certainly a symptom of something else, you might
want to post the results of EXPLAIN ANALYZE on that query.
P
On 30-Oct-06, at 11:33 AM, vamsee movva wrote:
> Hello all,
>            I am working with spatial tables  in postgresql with
> postgis support. i have two spatial data tables, one represents the
> whole state and another table represents the damaged locations in
> the state. My aim is to find number of damaged locations in every
> county or parish.
> Here i am giving the query i used to do this, could you please tell
> me whether i am doing right thing or not.
> "select count(*) from locations l1,county l2 where l1.the_geom &&
> l2.the_geom and intersects(l2.the_geom,l1.the_geom) and
> l2.countyid= some particular ID"
> It gave some results, but i am not sure whether the query is
> correct or not,
> I have one more problem with this query, this query taking lot of
> time when some particular ID ends with 9999(ex:220750501002999
> ,xxxxxxx9999), do u have any idea about this strange situation.
> excuse my english and method of requesting for help if there are
> any errors.
> Thanks in advance.
> have a nice day
> cheers
> vamsee
> On 10/30/06, strk at refractions.net <strk at refractions.net> wrote:
> On Mon, Oct 30, 2006 at 11:50:04AM -0600, vamsee movva wrote:
> > Hello all,
> >             I am using postgresql database with postgis support, i
> > understand postgis uses geos for geometrical calculations like
> contains(),
> > within() etc..
> >           I am faced some problems when i used these functions,
> > can i  ask for a help about them here?
> Don't ask to ask, just ask  :)
> --strk;
> geos-devel mailing list
> geos-devel at geos.refractions.net
> http://geos.refractions.net/mailman/listinfo/geos-devel
URL: http://lists.osgeo.org/pipermail/geos-devel/attachments/20061030/d8a47fdb/attachment.html
