cmake (was Re: [geos-devel] 3.0?)
=?GB2312?B?y++439PC?=
sungaoyong at gmail.com
Wed Sep 6 04:09:03 EDT 2006
copy CMakeList.txt and CMake dir to the geos-3.0.0rc1 dir,not
geos-3.0.0rc1/source
dir
On 9/6/06, Ëï¸ßÓ <sungaoyong at gmail.com> wrote:
> # CMakeLists.txt for geos 3.0 by sungaoyong
> # 2006-09-04 sungaoyong at gmail.com
> # Building on Cmake 2.4
> # test on windows mingw32 g++ 3.4.2¡¢msvc 2003,linux g++ 4.1
> # hope it's usefull
> # 2006/09/06 15:43:22 sungaoyong
> # use AUX_SOURCE_DIRECTORY to find source
> # some type check
> # capi build and Test
> # 2006/09/04 14:34:12 sungaoyong
> # first version,can build geos with cmake
> On 9/4/06, Mateusz Loskot <mateusz at loskot.net> wrote:
> > strk at refractions.net wrote:
> > > On Mon, Sep 04, 2006 at 09:21:28AM +0200, Mateusz Loskot wrote:
> > >> Sandro,
> > >> What do you think about adding 'build' and 'build/cmake'
> > >> directories to geos repo?
> > > Ok with me. Please make sure a 'make check' rule is included in the
> > > cmake build (we really want tests to be run)
> > strk,
> > Sure, but I won't have time earlier than at the beginning of October
> > In October I'll add cmake to SOCI library, so this may be a good
> > chance to update it in GEOS too.
> > Sun Gaoyong,
> > If you'd like to add "make check" target to your
> > cmake build earlier, please go on.
> > Cheers
> > Mateusz Loskot
> > http://mateusz.loskot.net
> > geos-devel mailing list
> > geos-devel at geos.refractions.net
> > http://geos.refractions.net/mailman/listinfo/geos-devel
URL: http://lists.osgeo.org/pipermail/geos-devel/attachments/20060906/92a0da52/attachment.html
