[geos-devel] Building under windows using mingw
Charlie Savage
cfis at savagexi.com
Tue Sep 12 12:14:17 EDT 2006
Geos 2.x.x builds fine under windows using MingW. Just do the usual
./configure, make, make install.
I haven't had any luck with Geos 3.x. The problem is a link issue where
declarations are defined twice, once in the .inc (contain inlines) files
are once in the header files. It should be simple to fix but I haven't
had the time to look into it.
Charlie
Tim Sutton wrote:
> Hi
> Is there any information available for building geos in mingw? Is it
> possible?
> Thanks
> Tim
Type: application/x-pkcs7-signature
Desc: S/MIME Cryptographic Signature
Url : http://lists.osgeo.org/pipermail/geos-devel/attachments/20060912/dc5b9a17/smime.bin
