[geos-devel] dirlist.mk not found
    Mateusz Loskot
    mateusz at loskot.net
    Thu Sep 28 10:14:20 EDT 2006
francesco wrote:
> That's the funny part, there is no such file anywhere.
> I downloaded the latest file geos-3.0.0rc1.tar.bz2.
I thought you are bulding GEOS from CVS.
Yes, it seems there is no dirlist.mk file geos package.
> I step into the <GEOSROOT>/source directory and then run nmake /f
> makefile.vc.  In that directory the only files are:
> --makefile.vc
> --makefile.in
> --makefile.am
Fast fix:
Open makefile.vc file
Remove following line, near the beginning of the file:
!INCLUDE dirlist.mk
if you will get some errors like "missing GEOS_DIRLIST..."
then, at the beginning of the makefile.vc add empty variable:
GEOS_DIRLIST=
Forgive me this inconvenience.
I'll fix this problem later.
Cheers
Mateusz Loskot
http://mateusz.loskot.net
