[geos-devel] Memory leaks in buffer module
Robert Coup
robert.coup at onetrackmind.co.nz
Thu Aug 23 02:09:13 EDT 2007
Hi Folks,
Spent a few hours today tracking down a few memory leaks in the geos
buffer code. Two of the leaks are visible by running valgrind against
docs/example.cpp.
I've attached a patch against HEAD that fixes it.
Regards,
Robert Coup
One Track Mind Ltd.
PO Box 1604, Shortland St, Auckland, New Zealand
Phone +64-9-966 0433 Fax +64-9-969 0045
Web http://www.onetrackmind.co.nz
Type: text/x-diff
Desc: not available
Url : http://lists.osgeo.org/pipermail/geos-devel/attachments/20070823/684db971/geos_buffer_memleak.bin
