[geos-devel] Updated SWIG bindings
Charlie Savage cfis at savagexi.com
Tue Aug 28 19:08:53 EDT 2007
Just a quick note...
I exposed a couple more methods in the SWIG bindings and regenerated
them using SWIG 1.3.31.  I also renamed a large number of the methods in
the Ruby bindings to be more "ruby" like - so Geometry::equals becomes
Geometry::eql?, etc.
I also added a geos_ruby project to Mateusz VC++ solution (and fixed a
minor #include bug when building the C API with VC++).  Its a bit grungy
in that I hard coded the path to my Ruby compiler, but it should be good
enough to get someone started.  Also note it creates a file called
geos.dll which of course can be quite confusing but is required by the
way Ruby loads libraries.  Thus the built DLL is kept under
msvc/geos_ruby/debug instead of msvc/debug to avoid any confusion.
If there is interest I can do the same for python.  But I'm not sure how
much those bindings are used versus the hand-crafted ones from Sean and
Hobu (kind of silly having 2 sets of bindings if you ask me, but alas).
I also updated the tests a bit, but I'm a bit confused by what is what
these days.  I see Mateusz added a bunch of unit tests (great) - but how
do those relate to the older xml tests?  The nice thing about the xml
tests is that the Ruby code could read them in, run the tests, and
verify the results.  Obviously that duplicates the C code testing
itself, but I think its still a good test of the bindings and memory
management through the c api.
Last - when using the bindings from Ruby (or Python) the lack of a
Coordinate object is fairly annoying - particularly when dealing with
points. Any chance it can be exposed via the c api?
Thanks,
Charlie
Type: application/x-pkcs7-signature
Desc: S/MIME Cryptographic Signature
Url : http://lists.osgeo.org/pipermail/geos-devel/attachments/20070828/51b3c209/smime.bin
