[geos-devel] Msys Sed error
Charlie Savage
cfis at savagexi.com
Thu Aug 30 01:27:28 EDT 2007
Ok got it.
> Here I've found something interesting:
> http://svn.navi.cx/misc/abandoned/opencombat/README.MINGW32
> check "Troubleshooting" section at the botton and 3rd Q&A.
> Charlie, could you check if this workaround will shoot the problem?
It wasn't this - but that gave me an idea.
The problem happened when running:
./configure --enable-swig
I tracked it down to geos/macros/ac_pkg_swig.m4, line 76:
else
AC_MSG_NOTICE([SWIG executable is '$SWIG'])
SWIG_LIB=`$SWIG -swiglib`
AC_MSG_NOTICE([SWIG library directory
is '$SWIG_LIB'])
$ swig -swiglib
C:\Development\msys\local\bin\Lib
C:/Development/msys/local/share/swig/1.3.31
Which makes sed unhappy. For comparison on Linux:
On linux:
[cfis at orthoceras ~]$ swig -swiglib
/usr/share/swig/1.3.31
I didn't see much use for including this information in the config
output, so I simply deleted the offending code and the problem went
aways. Phew.
Charlie
Type: application/x-pkcs7-signature
Desc: S/MIME Cryptographic Signature
Url : http://lists.osgeo.org/pipermail/geos-devel/attachments/20070829/40ad3b8f/smime.bin
