[geos-devel] timeval.h simplification
Charlie Savage cfis at savagexi.com
Thu Aug 30 13:55:04 EDT 2007
Getting MingW/Msys to work requires changing profile.h and timeval.h.  A
couple of years ago we added timeval.h since MingW did not include the
gettimeofday function.  However, this function was added to MingW last
summer so now the build blows up.
This comes into play in profiler.h, which has this rather obscure logic:
#ifndef _MSC_VER
#  include <sys/time.h>
#endif
#include <geos/timeval.h>
And then geos/timeval.h checks again for _MSC_VER, and if it is not set
  then sys/time.h is included.
I simplified this to:
#ifdef _MSC_VER
#else
#include <sys/time.h>
#endif
And removed the extra checking in geos/timeval.h.
So the rule is:
* If using MSCV++ include geos/timval.h
* If not, include sys/time.h
I have verified this works on MSYS and MSVC++ and am planning to check
the change in unless someone objects.
Thanks,
Charlie
Type: application/x-pkcs7-signature
Desc: S/MIME Cryptographic Signature
Url : http://lists.osgeo.org/pipermail/geos-devel/attachments/20070830/e0e53d1f/smime.bin
