[geos-devel] svn checkout problem
Frank Warmerdam
warmerdam at pobox.com
Mon Dec 10 16:07:48 EST 2007
Hugh Jennings wrote:
> Hi,
> I was hoping to get the current version of your code but I am
> experiencing a small problem. The configure script does not appear to be
> being checked out when I try to get your code.
> I believe am using the command as stated on your website. I have
> attached a file which shows the command and the results.
> I would appreciate any suggestions as to what I can do differently.
Hugh,
I believe you are expected to run the autogen.sh script in the geos
directory to generate configure and related derived files.
You may need reasonably modern versions of autoconf and automake installed
on your system for this to work.
Best regards,
and watch the world go round - Rush | President OSGeo, http://osgeo.org
