[geos-devel] svn checkout problem
Mateusz Loskot mateusz at loskot.net
Tue Dec 11 07:44:52 EST 2007
Hugh Jennings wrote:
>>> Hi,
>>> I was hoping to get the current version of your code but I am
>>> experiencing a small problem. The configure script does not appear to
>>> be being checked out when I try to get your code.
>>> I believe am using the command as stated on your website.  I have
>>> attached a file which shows the command and the results.
>>> I would appreciate any suggestions as to what I can do differently.
>> Hugh,
>> I believe you are expected to run the autogen.sh script in the geos
>> directory to generate configure and related derived files.
>> You may need reasonably modern versions of autoconf and automake
>> installed
>> on your system for this to work.
>> Best regards,
> Frank,
> Thanks.  I am not a programmer.
Then it's a good idea to download and use GEOS packages from the website
instead of use SVN version.
Cheers
Mateusz Loskot
http://mateusz.loskot.net
