[geos-devel] Geos 3.0.0 RC 4 on OS X 10.5
Paul Ramsey
pramsey at refractions.net
Wed Dec 12 23:41:54 EST 2007
Is it possible the fixes are in your sandbox, Mat and not committed?
I snapped that release off of trunk.
On 12-Dec-07, at 7:12 PM, Richard Greenwood wrote:
> Mateusz and William;
> Thanks for your help. With the two modifications, it compiled without
> error. Unfortunately, neither modification appear to be included in
> geos-3.0.0rc5.
> Rich
>>> I am trying to build Geos 3.0.0 RC 4 on OS X 10.5. HCoordinate.cpp
>>> fails because finite() is not defined. Changing it to the FINITE()
>>> macro fixes the problem. I notice that Revision 1.19 switched it
>>> from
>>> the macro to the function.
>>> I tried to post a bug report in Trac, but my OSGeo account seems
>>> to be
>>> completely foobar.
>> Richard,
>> This issue has been reported to the Trac and already fixed:
>> http://trac.osgeo.org/geos/ticket/162
>> If you have troubles with your OSGeo account, please follow the
>> section
>> about updating, perhaps it will help:
>> http://www.osgeo.org/osgeo_userid/
>>> Hmm, now the build is failing on:
>>> XMLTester.cpp: In function 'void tolower(std::string&)':
>>> XMLTester.cpp:75: error: 'std::tolower' is not a valid template
>>> argument for type 'int ()(int)' because function 'int tolower(int)'
>>> has not external linkage
>> Please, try to apply the fix I explained here:
>> http://lists.osgeo.org/pipermail/geos-devel/2007-November/003125.html
>> It's been also reported as ticket, but I've not applied this fix
>> to the
>> SVN yet:
>> http://trac.osgeo.org/geos/ticket/163
>> Cheers
>> Mateusz Loskot
>> http://mateusz.loskot.net
>> geos-devel mailing list
>> geos-devel at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/geos-devel
> Richard Greenwood
> richard.greenwood at gmail.com
> www.greenwoodmap.com
