[geos-devel] GEOS 3.1
Mateusz Loskot
mateusz at loskot.net
Fri Dec 21 11:38:18 EST 2007
Mark Cave-Ayland wrote:
> I would say though that it's worth spending a day going through the
> bugtracker and fixing any low-hanging fruit, with a particular emphasis
> on build fixes so we can be reasonably sure that trunk builds on
> everything *before* branching and merging in the changes (esp. since if
> Ben has been working with VC++, there are likely to be things in the
> merge that will break other compilers such as gcc).
Mark,
After Ben commits his work, we can observe how it builds on GCC in
buildbot: http://buildbot.osgeo.org:8506/
I build GEOS every day using Visual C++ and GCC, so I assume we will
clean gcc/vc++ issues pretty fast.
Cheers
Mateusz Loskot
http://mateusz.loskot.net
