[geos-devel] New problem when compiling QGis against geos 3.0.0rc4
Mike Leahy mgleahy at alumni.uwaterloo.ca
Thu Feb 15 12:49:08 EST 2007
Right - I remember you had pointed me to your patch when I asked about
rc3 in December, and that was what I had started from to get QGis 0.8.0
preview 2 to work.  After some additional help to make it work for both
GEOS 2.x and 3.x, I had posted an updated patch to the QGis developer
list.  It seems that the patch (or something similar) was applied in the
latest release (i.e., the distributed QGis 0.8.0 works with rc3 without
patching).  So I'm just wondering what's different about rc4 that might
cause this...
Mike
Mateusz Loskot wrote:
> Mike Leahy wrote:
>> Right, QGis does not officially support GEOS 3.x, but I helped with a
>>  patch it to make it work with rc3 prior to the 0.8.0 release, so I
>> know that it's not an accident that it works with rc3...
> I see.
> Just in case, here is one of my older patch for GEOS 3.0.0:
> http://mateusz.loskot.net/tmp/qgis-geos-3.0.0-mloskot-20061026.patch
>> I'm just wondering what's different that's making it break in rc4.
> I keep up Paul's suppositions.
> Also, check if you're builing with GEOS_INLINE macro and try to
> build without it. I've eperienced the inlining strategy as making troubles.
> I compared rc3 and rc4 and there are no differences related to
> Coordinate class or WKTReader class.
> So, I suppose the problem is specific to your environment.
> Cheers
