[geos-devel] GEOS SVN Geometry::contains bug!?
Oliver Baltzer obaltzer at cs.dal.ca
Mon Jul 23 20:07:29 EDT 2007
The contains relation is not commutative hence in source/geom/Geometry.cpp
lines 425-427 should be removed.
See:
bool
Geometry::contains(const Geometry *g) const
#ifdef SHORTCIRCUIT_PREDICATES
        // short-circuit test
        if (! getEnvelopeInternal()->contains(g->getEnvelopeInternal()))
                return false;
#endif
        // optimization for rectangle arguments
        if (isRectangle()) {
                return predicate::RectangleContains::contains((Polygon&)*this, *g);
 *       if (g->isRectangle()) {
 *               return predicate::RectangleContains::contains((const Polygon&)*g, *this);
        IntersectionMatrix *im=relate(g);
        bool res=im->isContains();
        delete im;
        return res;
Cheers,
Oliver
Oliver Baltzer
Faculty of Computer Science
Dalhousie University
Name: not available
Desc: Digital signature
Url : http://lists.osgeo.org/pipermail/geos-devel/attachments/20070723/7164af9e/attachment.bin
