[geos-devel] Binary Predicate Bug - Even Worse!
Todd Jellett
todd.jellett at caris.com
Thu Jul 26 10:34:25 EDT 2007
Martin Davis wrote:
> I agree with Chris and Paul. The predicates are clearly not intended
> to be mutually disjoint. They are probably intended to capture the
> most common use cases in single functions (which allows for some
> aggressive optimization - some day 8^).
> Refractions: 3, Jellet: 1 - we win! 8^)
This is not quite the answer I was looking for.
What I expected was something more along the lines of:
Yes, the named spatial relationship predicates based on the DE-9IM
(Disjoint, Touches, Crosses, Within, and Overlaps) are indeed mutually
exclusive. For a complete proof that these predicates are mutually
exclusive see the reference:
Clementini Eliseo, Di Felice P., van Oostrom p., A Small Set of Formal
Topological Relationships Suitable for End-User Interaction, in D. Abel
and B. C. Ooi (Ed.), Advances in Spatial Databases, Third International
Symposium. SSD ’93. LNCS 692. Pp. 277-295. Springer-Verlag. Singapore
(1993).
Here is an quoted excerpt from section 4.3 of this paper
"In this section, we will prove that the five relationships are mutually
exclusive, that is, it cannot be the case that two different
relationships hold between two features; furthermore, we will prove that
they make a full covering of all possible topological situations, that
is, given two features, the relationship between them must be one of the
five."
You (Todd) are probably being confused by the fact that Contains and
Equals are not true predicates. If you look at page 2-15 of the SFS, in
the second paragraph, you will see the five unique predicates listed. On
page 2-19, the SFS defines for user convenience, the predicates Contains
and Intersects. Note that these two, are not defined uniquely but
instead are defined in terms of one of the five unique and mutually
exclusive predicates. ( a.Contains(b) <=> b.Within(a) and
a.Intersects(b) <=> !a.Disjoint(b) )
Equals is not even listed as a predicate in SFS. It is just listed as a
method. In ISO 19107, it can be seen that Equals comes from the
transfiniteSet class along with the other set theoretical operations
like intersection, union and difference. In 19107, the GM_Object class
is derived from transfiniteSet. The SFS chose to optimize away the
transfiniteSet class so the Equals method ended up in the Geometry base
class (corresponds to GM_Object in ISO 19107) with all the other set
theoretical methods.
So in conclusion, having Within, Contains, and Equals all come back true
for two given geometries does not violate the mutual exclusivity of the
predicates because Within is the only true predicate.
