[geos-devel] nasty ring bug
strk at refractions.net
Mon Mar 5 04:59:39 EST 2007
On Wed, Feb 21, 2007 at 07:12:59AM -0500, Carl Anderson wrote:
> strk,
> you are free to uses these examples as you want.
> hole_from shell.xml is the example we hit in production use
> hole_red.xml is a reduced form of that
> big_nasty.xml is a cut and paste from your email about a reduced form of
> the big bad nasty buffer
> I want to run a few more tests in the production environment to see if
> any consequences of the patch pop up.
> I'll let you know in a few hours.
I've committed the two new testcases. big_nasty.xml is already in as
badguy3.xml. Please let me know if you found any problem with your
tests in production environmnet. Thanks.
--strk;
