[geos-devel] Polygonize produces wrong results
Düster Horst Horst.Duester at bd.so.ch
Fri May 11 02:52:37 EDT 2007
I try to use the polygonize function with PostGIS and ogr2ogr Interlis driver. In both cases geos 3.0.0RC4 may produce wrong results. Take a look at the attached images.
The image lines.png shows the initial situation. Many lines which represent 3 polygons.
The result of running polygonize shows the image result_polygon.png.
To reproduce this behaviour I attach the example line_test_small.zip geometry as shape-file.
The problem seems to be the very close postitioned vertex points at the two resolved curved features. When I reduce the number of these vertex points to half of numbers the polygonize process will finish successful. Try it out. It looks like a rounding problem??
My system
GCC-3.4.4
GEOS-3.0.0RC4
RedHat AS4
PostGIS 1.1.6
GDAL-SVN (20070509)
With best regards
Horst Düster
Dr. Horst Düster
GIS-Koordinator, Stv. Amtschef
Kanton Solothurn
Bau- und Justizdepartement
Amt für Geoinformation
SO!GIS Koordination
Rötistrasse 4
CH-4501 Solothurn
Telefon ++41(0)32 627 25 32
Telefax ++41(0)32 627 22 14
mailto:horst.duester at bd.so.ch
http://www.agi.so.ch
Type: application/zip
Desc: not available
Url : http://lists.osgeo.org/pipermail/geos-devel/attachments/20070511/6eb8b88a/line_test_small.zip
Type: image/png
Desc: not available
Url : http://lists.osgeo.org/pipermail/geos-devel/attachments/20070511/6eb8b88a/lines.png
Type: image/png
Desc: not available
Url : http://lists.osgeo.org/pipermail/geos-devel/attachments/20070511/6eb8b88a/result_polygon.png
