[geos-devel] XMLTester error
John Cartwright
john.c.cartwright at comcast.net
Fri Nov 23 00:27:55 EST 2007
Thanks Mateusz, that seems to work great!
I appreciate your prompt response.
--john
On Nov 22, 2007, at 6:48 PM, Mateusz Loskot wrote:
> John Cartwright wrote:
>> Hello All,
>> I'm trying to compile 2.2.3 on Mac OS 10.5 and running into the
>> following error:
>> XMLTester.cpp:66: error: 'std::tolower' is not a valid template
>> argument
>> for type 'int ()(int)' because function 'int tolower(int)' has not
>> external linkage
>> Can someone suggest how I might deal with it?
> John,
> There are two versions of tolower available in C++:
> old C functiona and new locale-aware function in C++.
> Apparently, GCC under Leopard introduces some changes
> that cause tolower is ambiguous if both prototypes of tolower are
> included and the function is through pointer to function what occurs
> in
> line 66.
> Could you try to replace the line 66 in file XMLTester.cpp with
> following line and see if it compiles for you now?
> std::transform(str.begin(), str.end(), str.begin(),
> (int(*)(int))std::tolower);
> Cheers
> Mateusz Loskot
> http://mateusz.loskot.net
> geos-devel mailing list
> geos-devel at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geos-devel
