[geos-devel] OSX 10.5 compile problem
Kevin Weller
kweller at asapwebsoft.com
Sat Nov 24 14:27:54 EST 2007
This one works for me too.
- Kevin
On Nov 22, 2007, at 8:08 PM, Mateusz Loskot wrote:
> William Kyngesburye wrote:
>> When compiling on OSX 10.5, I get an error in HCoordinate.cpp:
>> HCoordinate.cpp: In member function 'long double
>> geos::algorithm::HCoordinate::getX() const':
>> HCoordinate.cpp:197: error: 'finite' was not declared in this scope
>> If I use the 10.4u SDK it compiles (as it does in OSX 10.4).
>> Something
>> must have changed in <cmath>, but it's beyond me.
> William,
> Sorry for the long delay.
> I reported this problem to our brand new Trac along with proposing
> solution:
> http://trac.osgeo.org/geos/ticket/162
> I didn't applied this fix to SVN as I'd like to ask you for test.
> I don't have Leo installed yet.
> Could you replace the line 197 with new line proposed in the ticket,
> and see if it compiles for you?
>> PS. Is there something wrong with the bug tracker?
> We've migrated to OSGeo Trac:
> You can use the same credentials that you use for GDAL and other OSGeo
> projects.
> Cheers
> Mateusz Loskot
> http://mateusz.loskot.net
> geos-devel mailing list
> geos-devel at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geos-devel
Type: application/pkcs7-signature
Desc: not available
Url : http://lists.osgeo.org/pipermail/geos-devel/attachments/20071124/601666a6/smime.bin
