[geos-devel] testrunner fail
Gilles Bassière
gilles.bassiere at makina-corpus.com
Thu Oct 18 07:38:19 EDT 2007
Hi list,
I can't find a geos-users mailing list or any similar. If this message has nothing to do here, please redirect me. I tried to post on postgis-users but didn't get any answer.
A fatal error in PostGIS led me to investigate about my GEOS install. It seems broken but I can't find out why. Indeed, when I run a 'make check' in the build tree, I get:
Area of difference between obtained and expected: 4.98296e-05 -
Tolerated diff: 495.66 (SUCCESS!)
Area of difference between obtained and expected: 0 - Tolerated diff:
6.68967 (SUCCESS!)
3.14191 (SUCCESS!)
./testrunner: line 1: 12017 Segmentation fault (core dumped)
./XMLTester -v ./testLeaksBig.xml ./hexwkb.xml ./test.xml
./linemerge.xml ./TestInteriorPoint.xml ./TestCentroid.xml
./TestIsValid.xml ./TestValid.xml ./TestValid2.xml ./TestValid2-big.xml
./robustness.xml ./stmlf-cases-20061020.xml ./TestRobustOverlayFixed.xml
./fme.xml ./TestBufferExternal.xml ./heisenbugs.xml
./stmlf-cases-20070119.xml
FAIL: testrunner
I'm stuck now... How should I fix this ?
My config is:
- GEOS 3.0.0rc4
- Ubuntu Feisty (7.04)
- Proc AMD64 (though I use the i386 distro)
Geos is compiled with "--enable-python" and "--disable-inline" options, I also set a custom "--prefix". Python bindings are not so important to me, I could disable it if required but the inlining seems to be incompatible with QGIS.
Regards,
Gilles Bassiere
MAKINA CORPUS
30 rue des Jeuneurs
FR-75011 PARIS
http://www.makina-corpus.com
