[geos-devel] Windows Build
Charlie Savage cfis at savagexi.com
Thu Sep 6 20:21:44 EDT 2007
Hi Mateusz,
>> I was thinking it would be clever to just try to run Ruby/Python
>> directly and ask the interpreters themselves where they are.  That does
>> assume they are on the execution path though.  And it assumes you can
>> recover from errors if they aren't.  Can you work such magic in a batch
>> file?
> I think it should be possible to run it in prebuild actions,
> defined in .vcproj projects. I've not tried, but I suppose it's
> possible to assign values to new macro during prebuild.
> I can't check it ATM, but if you have problems, I'll play with it tonight.
I'd love to hand this over to you if that's ok - too much to do at the
moment (although I'm sure you have the same problem!).
Charlie
Type: application/x-pkcs7-signature
Desc: S/MIME Cryptographic Signature
Url : http://lists.osgeo.org/pipermail/geos-devel/attachments/20070906/f1908be1/smime.bin
