[geos-devel] GEOS and Writing SRID values
Charlie Savage cfis at savagexi.com
Thu Sep 13 12:38:55 EDT 2007
>> If this is a big issue, then a writeSRID flag could be added to the
>> WKBWriter.  But then you'd have to expose the flag via the CAPI -
>> maybe something like this:
>> extern char GEOS_DLL GEOS_getWriteSRID();
>> extern char GEOS_DLL GEOS_setWriteSRID(char value);
> Why char?  Why not an integer boolean?
Just following the standard already set in the C API (see isValid,
isSimple, isRing, etc.).
> I must say I hate the way the GEOS C API uses static state in the library
> for stuff like byte order and output dimensions and I hate to perpetuate
> this.  This is a threading risk especially in situations where different
> parts of an application are using GEOS can cannot easily cooperate with
> locks.  This is the sort of problem my clients are running into more and
> more with libraries like GEOS, PROJ.4, etc.
I agree - but that's separate thing, no?  The right solution is expose
the reader/writers to the capi so you can create one and then use it.
> I'd like to see an extension to the C API adding:
> GEOSGeomToHEX_bufWithOpts( const GEOSGeometry *g, size_t *size,
>                            int byteOrder, int includeSRID,
>                            int outpuDimension );
Yes, that would be better than the current api.  But really all the
writer methods (toWkt, toWkb, toHex) should work like that (with
different options for toWkt, just srid I think).
If we could start from scratch, you'd change those 3 methods and get rid
of these 4:
extern int GEOS_DLL GEOS_getWKBOutputDims();
extern int GEOS_DLL GEOS_setWKBOutputDims(int newDims);
extern int GEOS_DLL GEOS_getWKBByteOrder();
extern int GEOS_DLL GEOS_setWKBByteOrder(int byteOrder);
Which would make for a more compact, and bettter, api.
> or perhaps, merge the options into a bitfield so we can easily
> add new bitfield values in the future without changing the C
> API which needs to be quite static.
Are there going to be other options besides those 3 (byte order, include
srid, output dimension)?
So your conclusion is add in 3 new methods (toWktWithOpts,
toWkbWithOpts, toHexWithOpts) and deprecate the original 3 methods and
the 4 above)?
Is the geos 3.0 capi still backwards compatible with the 2.x apis?
Charlie
Type: application/x-pkcs7-signature
Desc: S/MIME Cryptographic Signature
Url : http://lists.osgeo.org/pipermail/geos-devel/attachments/20070913/9341c2c8/smime.bin
