[geos-devel] Union problem
mchapman at texelinc.com
Sun Apr 6 11:19:37 EDT 2008
Thanks Ari. I think I may be using an older version of GEOS. VantagePoint is a cheesy desktop tool I'm building for emergency responders. I really appreciate your help. I will try RC4 and see if that fixes the problem.
Best regards,
Martin
Sent via BlackBerry by AT&T
-----Original Message-----
Date: Sun, 06 Apr 2008 16:43:24
To:GEOS Development List <geos-devel at lists.osgeo.org>
Subject: Re: [geos-devel] Union problem
I tried this with GEOS 3 RC4 (from Perl and through GDAL) and it works
fine. The border between US and Mexico disappears :)
What's VantagePoint? Maybe it's using old GEOS or otherwise doing
something wrong?
Regards,
Ari
Martin Chapman kirjoitti:
> Martin,
> Here you go. It occurs when you union the US and Mexico. Thanks for your
> help!
> Best regards,
> Martin
> From: geos-devel-bounces at lists.osgeo.org
> [mailto:geos-devel-bounces at lists.osgeo.org] On Behalf Of Martin Davis
> Sent: Thursday, April 03, 2008 12:32 PM
> To: GEOS Development List
> Send me the shapefile and I'll try it out in JTS.
> M
> Martin Chapman wrote:
>> Unfortunately, I do not have JTS but I will try to step through the code
> and
>> see if I can learn more about the problem. Perhaps a careful inspection
> of
>> the input and output point sets will yield some clues because the problem
> is
>> predictable.
>> Best regards,
>> Martin
>> [mailto:geos-devel-bounces at lists.osgeo.org] On Behalf Of Paul Ramsey
>> Sent: Thursday, April 03, 2008 11:50 AM
>> Most probably a bug... any chance you could run this same test case
>> under JTS so we can confirm if it's a problem at the algorithm level
>> or the port level?
>> Thanks,
>> P
>> On Thu, Apr 3, 2008 at 10:47 AM, Martin Chapman <mchapman at texelinc.com>
>> wrote:
>>> All,
>>> When I union the two features USA and Mexico I end up with a geometry
> that
>>> has one point where the y or lat value for one point is zero. See the
>>> attachment for what I mean. Does anyone think this is a bug in GEOS or
> am
>> I
>>> not doing something correctly? Most other geometric unions create good
>>> geometries. If you want I can send the original shape file.
>>> Thanks for any help.
>>> Best regards,
>>> Martin
>>> geos-devel mailing list
>>> http://lists.osgeo.org/mailman/listinfo/geos-devel
Prof. Ari Jolma
Geoinformatiikka / Geoinformatics
Teknillinen Korkeakoulu / Helsinki University of Technology
tel: +358 9 451 3886 address: POBox 1200, 02015 TKK, Finland
Email: ari.jolma at tkk.fi URL: http://www.tkk.fi/~jolma
