[geos-devel] Binary predicate shortcuts
Martin Davis mbdavis at refractions.net
Mon Apr 28 12:45:12 EDT 2008
Neither GEOS nor JTS checks for identical geometries as input to the
predicates.
What's your use case for this?  At first glance it doesn't seem like it
would be a major source of performance loss.
You could always check for this in your wrapper..  8^)
Sean Gillies wrote:
> Could GEOS not return known results immediately when evaluating binary
> predicates where both geometries are the same (same address in memory)?
> If this is already done, it's buried deeper in the code than I've
> looked, or I've completely missed it.
> Sean
> geos-devel mailing list
> geos-devel at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geos-devel
Martin Davis
Senior Technical Architect
Refractions Research, Inc.
(250) 383-3022
