[geos-devel] GEOSBuffer doesn't take all of my geometry
Maximo Pech makzpj at gmail.com
Mon Apr 28 18:07:07 EDT 2008
Well, I will explain you why I have this weird geometry.
The application I'm coding uses 2 esri shapefiles, one of them is huge, it's
the size of Mexico, and the shape of it is very similar to Mexico. It's a
huge multipolygon 24M in size.
Then I have another shapefile, the size of a city, this one is made of many
polygons and it's smaller.
I have to calculate the intersection percent between the first and the
second shapes.
To do this I convert both shapefiles to WKT, so I end up with a huge WKT 54M
in size from the first shapefile and many small WKT's from the second one.
Problems start with the first shape, the huge one, having lots of
self-intersections. I tried to "fix" it by doing a GEOSbuffer on it, but
after some calculations, GEOSBuffer fails with an error I don't remember.
After that I tried spliting the huge WKT multipolygon into many smaller WKT
polygons, and applying a GEOSBuffer to each one of them when needed, but
this doesn't work either because many of the resulting polygons are screwed
up, and I can't discard any of them. Also there is no way I can get a
shapefile with a valid multipolygon inside it, I have to find a way to make
it usable for GEOSIntersection.
2008/4/28 Martin Davis <mbdavis at refractions.net>:
> When I look at the geometry fragment you provided, the "hole" actually
> lies completely outside the shell.  If the other holes are the same, then
> buffer just removes them entirely.
> In other words, buffer is behaving according to spec - it's just that your
> input geometry is too munged to be fixed by buffer.  8^)
> Maximo Pech wrote:
> > Hi, I'm having trouble with a geometry in WKT form, it begins like this:
> > POLYGON ((-97.3813520229492866 26.0028241269227607, -97.3813272725338663
> > 26.0046293743595065, -97.3793295485156989 26.0046069937576725,
> > -97.3793543294448654 26.0028017481029394, -97.3813520229492866
> > 26.0028241269227607), (-97.3813520229492866 26.0028241269227607,
> > -97.3813767710094567 26.0010188790133867, -97.3793791080158968
> > 26.0009965019755249, -97.3773814473803014 26.0009740973626933,
> > -97.3753837891055838 26.0009516651750232, -97.3753589495133269
> > 26.0027569077319392, -97.3753341075571370 26.00456214981606...
> > It's a polygon with many rings inside it. I'm trying to buffer it to
> > make a intersection operation with a lot of other geometries because GEOS
> > says it has a self-intersection at or near point -97.3814 26.0028, but after
> > buffering it my geometry becomes:
> > 26.0028241269227607))
> > All of the remaining rings are gone.
> > geos-devel mailing list
> > geos-devel at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/geos-devel
> Martin Davis
> Senior Technical Architect
> Refractions Research, Inc.
> (250) 383-3022
URL: http://lists.osgeo.org/pipermail/geos-devel/attachments/20080428/9c56a2b6/attachment.html
