[geos-devel] How to destroy PreparedGeometry object?
Martin Davis
mbdavis at refractions.net
Mon Aug 11 18:38:20 EDT 2008
I would think that there should be a destructor defined for the
PreparedGeometry class. Would this be the appropriate C++ pattern?
Mateusz Loskot wrote:
> Folks,
> There is PreparedGeometryFactory class with create/prepare methods.
> Both return object of PreparedGeometry type dynamically allocated on
> heap (using new operator).
> Now, how such geometry returned from the factory is supposed to be
> destroyed?
> Comparing to GeometryFactory, there is destroyGeometry method that
> accepts pointer to object of Geometry type. It works well.
> Back to prepared geometry, GeometryFactory::destroyGeometry() can not
> be used to destroy object of type of PreparedGeometry because it is
> unrelated in any way to Geometry type, so no casting is possible.
> For me it looks that there is one method missing
> PreparedGeometryFactory::destroyGeometry, though I may have missed
> some other way to destroy prep geom.
> Any suggestions?
> Best regards,
Martin Davis
Senior Technical Architect
Refractions Research, Inc.
(250) 383-3022
