[geos-devel] How to destroy PreparedGeometry object?
Mateusz Loskot
mateusz at loskot.net
Mon Aug 11 19:10:45 EDT 2008
Martin Davis wrote:
> Ugh.
> Sounds like we need a
> PreparedGeometryFactory::destroyPreparedGeometry(PreparedGeometry *)
> method, then - as per your suggestion.
or just
PreparedGeometryFactory::destroy(PreparedGeometry* )
as we have prepare() and create() but not preparePreparedGeometry etc.
(Actually, I would vote for renaming destroyGeometry() to just destroy()
from the same reasons, but I understand it's likely impossible as it
breaks public API)
> Does this same situation exist for all objects which might be allocated
> on the heap?
Yes, it does exist for all objects that:
a) are allocated on the heap
b) and are returned outside GEOS, to user
c) and the ownership is transfered to user
The c) means that a user is responsible for destroying it.
> There's lots of classes in GEOS "below the Geometry level"
> which might be used by a coder using the C++ API. Perhaps there should
> be a warning about this (in the non-existent FAQ?)
Yes, FAQ is good, but empty:
http://trac.osgeo.org/geos/wiki/FAQ
The explanation can be stolen from GDAL FAQ with some changes related to
GEOS. Before I compile something, I need to find more examples of
potentially dangerous places in GEOS.
Best regards
Mateusz Loskot, http://mateusz.loskot.net
Charter Member of OSGeo, http://osgeo.org
